Oil leak
Old January 3rd 05, 10:32 PM
Ron Rosenfeld
On 2 Jan 2005 16:29:32 -0800, "Gene Seibel" wrote:
I have a 1966 Cherokee 180 with fixed pitch prop. I have noticed some
oil streaks on the back plate of the prop spinner, apparently seeping
out between the prop and flywheel. Anyone have an expereince with this?
Is there a plug in the front the hollow (I assume) crankshaft that
could be leaking? Is this a common problem? Thanks for any info.
There is a seal at the front of the engine where the crankshaft exits.
It's glued in place and the glue can come loose.
Replacing it takes a few hours, as the prop needs to be removed and
replaced, but shouldn't be a big deal for an experienced technician (if
that's what's causing the leak).
oil leak question Dick Home Built 18 November 19th 04 04:14 PM
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ ~ THE CHOKING CHIMP ~ Military Aviation 0 June 6th 04 06:34 AM
Pazmany PL2 strut leak moni nut Home Built 1 April 27th 04 03:24 AM
oil leak fixed - breaking in new cylinders Michael 182 Owning 24 September 23rd 03 01:36 PM
Oil Leak in TR182 Michael 182 Owning 2 August 17th 03 08:13 PM
