oil leak fixed - breaking in new cylinders
Old September 17th 03, 09:45 PM
Michael 182
Default oil leak fixed - breaking in new cylinders
A while ago I posted about an incurable oil leak in my '79 TR-182. Turned
out to be rings. Decided to get a top overhaul. Now I am breaking in the new
cylinders.
On one hand I've been told, in capital letters, "DO NOT BABY THE ENGINE"
On the other jand I've been told to maintain CHT of 325-350, which is quite
a trick given no cylinder thermometer. One mechanic said to just keep it in
the green for the first 20 hours to keep the turbo from generating too much
heat.
Any comments?
Michael
Old September 17th 03, 10:00 PM
Scott Skylane
cylinders.
/snip/
Michael,
Glad I could help! As far as break-in, just fly at least as hard as you
normally would, and she'll be fine.
Happy Flying!
Scott Skylane
N92054
Old September 17th 03, 10:19 PM
Ron Natalie
"Michael 182" wrote in message news:uR2ab.374025$cF.110854@rwcrnsc53...
heat.
You don't have a CHT or you don't have one on that cylinder? I thought 182's
had at least a single point CHT.
Old September 17th 03, 10:45 PM
Michael 182
I don't think I have one - have an egt and a carb temp. I'll look again when
I get in the plane, but I can't picture it.
quite
in
much
heat.
182's
Old September 17th 03, 10:47 PM
Michael 182
Including using the turbo for climb (which puts out a ton of heat)?
"Scott Skylane" wrote in message
Turned
new
cylinders.
/snip/
Michael,
Happy Flying!
Scott Skylane
N92054
Old September 17th 03, 10:59 PM
Dan Luke
CHT of 325-350
Both correct. Running at high power is necessary to seat the rings. Low
temperature is necessary to prevent glazing the cylinders.
Keep the cowl flaps open and the mixture rich. Keep the power high - don't
fly so high that power is reduced below 75% until the cylinders are broken
in.
How come you don't have a CHT gauge?
Dan
C172RG at BFM
Albert
FAR 23.1305(b)(3) says you need a CHT indicator for each air cooled engine
with cowl flaps. There ought to be one there somewhere.
et...
when
quite
it
in
much
heat.
182's
Old September 17th 03, 11:19 PM
Ron Natalie
"Michael 182" wrote in message et...
Do you have cowl flaps?
Old September 17th 03, 11:23 PM
Ron Natalie
"Dan Luke" c172rgATbellsouthDOTnet wrote in message ...
in.
Here's Mattituck's take on it.
http://www.mattituck.com/new/articles/engbrkin.htm
Old September 18th 03, 01:30 AM
Newps
heat.
Bottom left gauge in the six pack. Although there is no temps shown
except a middle one and a red line.
IO470-E cylinders gabriel hatch Aviation Marketplace 0 October 24th 04 02:02 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ ~ THE CHOKING CHIMP ~ Military Aviation 0 June 6th 04 06:34 AM
0-320 cylinders Drew Dalgleish Home Built 9 December 8th 03 05:25 PM
Oil Leak in TR182 Michael 182 Owning 2 August 17th 03 08:13 PM
