Torque values for oil screen
Old January 22nd 05, 10:22 PM
Scott Skylane
John Clonts wrote:
Could someone please tell me the proper torque for the oil screen housing in my IO-520-FCL? Also the oil drain
plug? I can't get hold of my A&P until Monday but I want to change the oil tonight...
Thanks!
John Clonts
Temple, Texas
N7NZ
John,
Both of these items use a copper crush gasket for sealing. I am not
aware of any "torque" value published for such items. Using *new*
gaskets, turn the screen/plug in until gasket contact is made, then an
additional 1/4 turn (45 degree rotation) should do it. As you are
turning your wrench, you will feel the friction gradually increase,
until proper compression is achieved, at which point the friction starts
to rapidly increase. This is sometimes called the "calibrated elbow"
approach, and is quite adequate for these types of gasket.
As a side note, a quick drain plug greatly simplifies this procedure, if
space permits. As far as the oil screen goes, most people safe-tie
these, but is not necessary. Take a look at the next TCM factory
new/overhauled engine you get a chance to see.
Happy Flying!
Scott Skylane
N92054
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 02:30 PM
Narrow Foil Strips for Ground Plane Dennis Mountains Home Built 22 August 29th 04 02:09 AM
Foil Antenna on Carbon Fiber Dennis Mountains Home Built 7 April 24th 04 01:54 AM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 01:18 AM
Garmin 195 screen problem BPattonsoa Home Built 30 December 3rd 03 03:14 AM
