On Fri, 21 Jan 2005 22:01:14 -0500, Mike W. wrote:
I assume you are flying something like a 115c or other aerobatic trainer? Like another poster mentioned about props, this machine was probably built with emphasis on climbing, not cruising. How about takeoff? Do you only use partial throttle? What does the tach read when you throttle up? Yes, it is a 115C. I do use full throttle at takeoff and climb. Usually around 2300 at the start of the roll. After takeoff, I have to be careful to keep the pitch to about 80 kts to stay under redline. At level-off, power reduction always comes before pitch down. |
| Thread Tools | |
| Display Modes | |
| Propellor Primer | Ebby | Home Built | 3 | November 19th 04 11:36 AM |
| most of eastern Massachussetts airspace closed in July | Christopher C. Stacy | Instrument Flight Rules | 29 | June 19th 04 01:47 AM |
| Throttle friction lock slipping - How do I stop this? | Ron | Home Built | 2 | January 24th 04 01:55 AM |
| WOT in cruise? | Roger Long | Owning | 10 | July 28th 03 09:00 AM |
| Rotax 912 Full Throttle Springs | Mark Callahan | Home Built | 0 | July 5th 03 02:31 PM |
