"Kiwi Jet Jock" wrote in message
... Additionally, some might be interested in doing some experiments dumping flap during a simulated engine failure on approach to work out at what height the additional height loss (in dumping the flap) is (more than) compensated by the increased gliding range. Interesting. "Dumping", you mean retracting, right? The idea being to reduce the drag & preserve energy to extend the glide distance? I'd have thought that above 'best glide' speed, you'll always extend your glide distance - without any associated additional height loss if you pitch to maintain airspeed - by retracting flaps. After all, at constant speed, you'll be cleaner and dissipating less energy -- energy which can only come from the loss of your (2.m.g.h) potential energy as you descend. (If this wasn't the case, the POH would tell you to add flaps to configure for best glide). Below best glide, things aren't as clear. It may be that the induced drag with flaps out is less than that when clean. Well, for low setting flap settings, anyway. In the worse case, you should only need to get back to best glide, which means the additional height loss will be the potential energy needed to increase your speed. 0.5 * m * (v'-v)**2 = 2*m*g*h (v'+v)*(v'-v) = 4*g*h so for v' (best glide) = 70knots = 120 ft/sec, v (approach speed) = 60 knots = 100 ft/sec, height loss works out at about 35 ft. Now in my 182, I typically maintain 70 knots (which happens to be my best glide speed) until short-ish final, so I know exactly what I'll be doing if the engine conks out (assuming I've been obliged to take the 'grand tour' behind someone, or I'm coming in on the final 1/2 mile or so of an ILS). I slow to 60 when I'm pretty sure I'll make the airport property, if not the runway itself, so exactly what the optimum response to an engine failure might be in the low speed régime doesn't concern me that much. Of course, with a headwind, you'd normally trim for slightly more than best glide speed to increase your range. But that's another topic. |
| Thread Tools | |
| Display Modes | |
| Nader calls White House Israel's puppet -ot | Grantland | Military Aviation | 0 | July 2nd 04 07:39 AM |
| White soot on exhaust | R. Wubben | Owning | 4 | April 19th 04 05:46 PM |
| Study shows USAF makeup mostly white, male | Otis Willie | Military Aviation | 0 | January 27th 04 11:01 PM |
| F-104 White Wings? | Jack G | Military Aviation | 1 | January 24th 04 10:24 AM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
