flight level in Flight simulator
Old August 20th 03, 12:15 PM
Robert
Default flight level in Flight simulator
Hi!
I have three questions about fling in FS.
1. what does it mean when ATC says. climb at FL290, for example. what
height is it?
2. when ATC said that I have do climb to 11,000 and reached that level
ATC said that I`m 2000m above my flight level. Internationa settings
are set to metres. but also if I set the settings to feets the numbers
were not coresponding.
3. what should I do whet ATIS or ATC says, i do not know exactly,
something about the pressure or height on target airport.
Thanks in advance
Robert
Old August 20th 03, 04:35 PM
CanadianPilot
"Robert" wrote in message
om...
Hi!
height is it?
29000 ft
could be that your altimeter is not set up propelly have a look on the right
side you have a moveable scale from 28.00 to 31.00 that where when ATIS or
ATC tell you the setting you need to enter it
Thanks in advance
Robert
Old August 20th 03, 07:29 PM
treefroginometry
om...
Hi!
height is it?
This question might be more applicable in rec.aviation.simulators
FL290 would be 29,000ft
Old August 20th 03, 08:37 PM
shywon
Robert wrote:
Hi!
height is it?
29,000 feet
You probobly did not set your altimeter by pressing B
Press B to set the altimeter
Thanks in advance
Robert
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 05:24 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
