#11
"Big John" wrote in message ... rgb We've had aluminum auto engines without liners and as I recall they had a pretty high cylinder failure rate? Chevy Vega. About as close to100 percent failure rate as you can get. |
rgb wrote in message ...
Some folks seems to be pretty please with there Rotax 912S so I was thinking those 2 new engines might give Lycoming and Continental a little challenge, maybe not ... For what I can see thoses good old Lycomings are quiet good, but kindof expensive . Liquid cooling looks like it'll make it difficult to retrofit to existing designs. I wouldn't be surprised to see a company like Diamond modify one of their designs for it. How they can run a 10.8 to 1 compression ratio on 87 octane gas is a neat trick. I'm sure temp stabilization from liquid cooling helps, but that still seems like a very high ratio for the low octane fuel. John Galban=====N4BQ (PA28-180) |
Big John wrote:
Some of the things I invented and patented, I checked for 100's of thousands of cycles and yet when put in field, always found someone who could tear them up G I guess you call that trying to design for the lowest common denominator (which don't always work as the lower you get on the "Darwin' scale the harder it is to keep people from using the wrong way and tearing up). G Well-known principle; whenever you think you have a fool-proof design, they come out with a better class of fool! -- Alex Make the obvious change in the return address to reply by email. |
alexy
Never heard it that way before but of course your right G Big John On Sat, 18 Oct 2003 02:51:23 GMT, alexy wrote: Big John wrote: Some of the things I invented and patented, I checked for 100's of thousands of cycles and yet when put in field, always found someone who could tear them up G I guess you call that trying to design for the lowest common denominator (which don't always work as the lower you get on the "Darwin' scale the harder it is to keep people from using the wrong way and tearing up). G Well-known principle; whenever you think you have a fool-proof design, they come out with a better class of fool! |
Pepperoni,
The problem that I see is that Based upon what? Are you an engine construction engineer specializing in aluminum engines? Or is it just "gut feel"? the engines run up to 6000 rpm, and are geared 3:1. Not in cruise. but more problems seem folded back in with the liquid cooling. Again: Says who? Liquid cooling seems to be a total non-issue with the Rotaxes, the new diesels and engines in general. -- Thomas Borchert (EDDH) |
Rgb,
I don't know alot about engines So how do you know the material they are made of is a problem, as you say in your original post? -- Thomas Borchert (EDDH) |
Rgb,
For what I can see thoses good old Lycomings are quiet good, Well, time to become an owner then. And then you'll change your mind real quick, after, say 600 hours or so. -- Thomas Borchert (EDDH) |
John,
Liquid cooling looks like it'll make it difficult to retrofit to existing designs. Why? The Thielert diesel is liquid cooled and is being retrofitted to C172s and PA28s as we speak. Everything firewall forward is replaced, so where's the problem? -- Thomas Borchert (EDDH) |
Jim,
Well, then check on the prices for the Thielert. You'll be surprised. Also, the sma has come down to 60k, AFAIK. -- Thomas Borchert (EDDH) |
| Thread Tools | |
| Display Modes | |
| Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 11:14 PM |
| Questions Rotax Engines | Mark Smith | Home Built | 2 | August 14th 04 12:01 AM |
| Jabiru and Rotax engines | Marco Rispoli | Home Built | 14 | July 16th 04 08:23 AM |
| Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 10:36 PM |
| Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 06:36 PM |
