But there can't be a relative wind unless some other force is acting on the
plane. It goes along with the wind just like a raisin in a cake. If the wind changes speed or direction suddenly, the inertia of the plane drags the raisin through the cake briefly creating relative wind until the plane reaches the same speed as the wind. The inertia is acting briefly like an outside force. Take a look at the next weathervane you see. It has a pivot attached to the roof which is attached to the ground. Take a look at the next airplane you see... An airplane is not a weathervane. Let's say you are in a open cockpit airplane in no wind. You are hit from the side by a sudden 75 knot gust that continues as a steady wind. Because of the inertia, the plane does not start moving sideways at 75 knots instantly. You will experience a brief moment of 75 knots of wind on your cheek which will rapidly diminish as the plane picks up sideways speed. Because the vertical tail is well aft of the center of gravity, the plane may well "weathervane" into the wind as you suggest. The inertia of the plane, acting through the center of gravity, which is point bodies in space tend to rotate about, is briefly the pivot of the weathervane. The plane will quickly accelerate to 75 knots sideways motion. When it reaches the speed of the wind, there will be not further evidence of wind (and no further weathervane tendency) except by looking at the ground. If you were in a hot air balloon, you would also feel a sudden strong wind that dropped of very quickly to zero after which you would be sailing across the landscape at 75 knots but able to light a candle in the basket and not see if flicker a bit. -- Roger Long Kobra wrote in message ... Do I fly?! Don't be a wise ass...why do you think they call it "weathervaning"? What does a weathervane do? It turns the "weathervane" into the relative wind. An airplane is a weathervane too and the wind can and does turn an airplane into the relative wind. Definition: "weathervaning". Kobra "CASK829" wrote in message ... The tail does not know what direction the wind is blowing if the airplane is in the air. So therefore it DOES NOT push the nose into the wind. Do You fly? It's from the wind striking the vertical stabilizer and pushing the nose into the wind. Kobra |
| Thread Tools | |
| Display Modes | |
