28 volt pitot heat
Old March 26th 04, 11:56 PM
B2431
Default 28 volt pitot heat
Will running a 28 volt pitot tube heat on 12 volts heat it enough to use? I
keep seeing 28 volt pitot tubes on e-bay and was wondering if they would do the
job.
Dan, U.S. Air Force, retired
Old March 27th 04, 12:57 AM
rip
No. A 28 volt pitot on a 14 volt system will only develop 1/4 of the
design wattage. I feel your pain; the price of pitot tubes these days is
absolutely, downright obscene.
Rip
job.
Old March 27th 04, 04:03 AM
Richard Riley
On Fri, 26 Mar 2004 23:57:43 GMT, rip
:No. A 28 volt pitot on a 14 volt system will only develop 1/4 of the
:design wattage. I feel your pain; the price of pitot tubes these days is
:absolutely, downright obscene.
:Rip
:B2431 wrote:
: Will running a 28 volt pitot tube heat on 12 volts heat it enough to use? I
: keep seeing 28 volt pitot tubes on e-bay and was wondering if they would do the
: job.
Keep watching Ebay, I picked up a 12 and a 24 as a package for $18,
new old stock.
Old March 27th 04, 04:35 AM
UltraJohn
Hummmmm
If you take a ceap 12v to 110 ac power inverter from Radio Shack and tack a
24-30 volt bell transformer with a rectifier and filter on the output you
could make your own 12v to 24 volt dc converter for about $20-$30 dollars.
Ask Jim Weir if he can come up with a project ;-)
John
:Rip
: use? I keep seeing 28 volt pitot tubes on e-bay and was wondering if
: they would do the job.
new old stock.
Old March 27th 04, 05:23 AM
UltraJohn
Actually I just looked up the current requirements and that would not work!
I have found a site (www.solarseller.com) that carries the Solar
Converters, inc line of converters.
(model cv 12/24 - 50r24 looks to be what your need but check with them) it
appears to cost around $175.00 I don't know how cost effective that is!
Just a possibility
John
UltraJohn wrote:
Hummmmm
a 24-30 volt bell transformer with a rectifier and filter on the output
you could make your own 12v to 24 volt dc converter for about $20-$30
dollars. Ask Jim Weir if he can come up with a project ;-)
John
:Rip
new old stock.
Old March 27th 04, 05:25 AM
B2431
Hummmmm
John
I wouldn't think you'd need to filter it. or rectify it. I bet the heater would
be happy with AC.
As a matter of fact I have seen pitot tubes with 115 VAC heaters.
Old March 27th 04, 11:19 AM
Big John
rip
It might be possible?
Use an inverter and diode rectifirer of the resulting A/C or just run
on A/C.
One of our retired electrical engineers could probably come op with a
set of plans to build or how to modify a commercial Inverter
(12DC/110VAC) you can buy anyplace.
A basic question. How many homebuilts are IFR certified and are flown
in icing conditions and need a heated pitot tube?
Big John (I been lurking troops )
Rip
job.
Old March 27th 04, 05:23 PM
Richard Riley
On Sat, 27 Mar 2004 04:19:00 -0600, Big John
:A basic question. How many homebuilts are IFR certified and are flown
:in icing conditions and need a heated pitot tube?
A significant number are IFR certified. None (or nearly none) are
flown in *known* icing - it's when happens despite your best efforts
that you don't want it to kill you.
I don't think I'm going to put pitot heat on mine, despite a fully
redundant Uuber IFR panel from the 6th circle of Hell (2 of everything
except engine instruments). A while back I tried putting a post-it
note over my airspeed indicator, and found I could land just fine.
GPS gave me a general idea of airspeed, I knew what my approach looked
like and how much power I was carrying. If the nose started to bob, I
added a touch of power. I wouldn't do it in a conventional
configuration but in a canard it worked surprisingly well.
Old March 29th 04, 01:55 AM
Ray Toews
Don't waste your money and add the weight, learn to fly without a
pitot. mine has been frozen all winter (no place to warm it up) and I
have been doing fine. Kind of works as a back up altimeter tho
Spend the money you save on gas.
Ray
job.
Heat treating wing ribs Holger Stephan Home Built 13 February 4th 04 12:59 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 08:25 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
