Stealth bird
  #21
Old November 27th 03, 03:28 AM
Viperdoc
Remember that props are usually metal, as well as gear legs. Also, altitude
and direction relative to the radar site also will determine the quality of
a primary return.
"Big John" wrote in message
Dave
Your words brought back memories. TNX. Should have remembered.
I still think homebuilders can build a Stealth bird.
Some shielding like in the 117 might be an easy way to reduce return
from areas that are not 'glass'.
Big John
On Wed, 26 Nov 2003 17:06:41 -0500, Dave Butler
Big John wrote:
I'm not up to speed on current traffic control radar and if they both
'skin paint' and look at transponder returns?.
What you're calling 'skin paint' is what ATC calls "primary radar". The
ATC
system that processes transponder returns is called "secondary radar",
also
known as ATCRBS (Air Traffic Control Radar Beacon System).
Both kinds of radar operate simultaneously and using antennas that rotate
together.
Occasionally you'll hear that either primary or secondary radar is out of
service at a particular facility. If secondary radar is out of service
they have
to use some other means of identifying the primary radar returns. If
primary
radar is out of service, they can see only transponder-equipped aircraft.
Remove SHIRT to reply directly.
Dave
North Korea Denounces US Stealth Bomber Deployment Otis Willie Military Aviation 0 July 2nd 04 10:20 PM
Why is Stealth So Important? James Dandy Military Aviation 148 January 20th 04 05:17 PM
F-32 vs F-35 The Raven Military Aviation 60 January 17th 04 09:36 PM
How long until current 'stealth' techniques are compromised? muskau Military Aviation 38 January 5th 04 05:27 AM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 04:40 PM
