Well, it's not my toy. My toy is a Velocity. Also foam but a wee bit
stronger. Thanks for the condescending remark. After looking closely at how this thing is put together, I would say that your analysis is right on the money. The aluminum tube/foam spar is an awfully wiggly thing and I can't imagine it being much stronger with ice cooler Styrofoam for structure. I'll probably wind up cutting the plane into a million little parts and selling the oversized lawn blower motor for whatever it can get. At least the guy who owned this before passed away of natural causes and not the ground rushing up to smite thee... Dale Alexander Velocity 173 RG Elite-another foam plane. "plasticguy" wrote in message ... I watched a Goldwing crash when the right wind failed on a moderate g pullup. I was behind it after it flew overhead. The spar was an aluminum tube inside a foam structure. It looked to fail in bending about a foot outboard of the r/h attach points. The pilot stayed in the fuse until impact and lived for a short time after the crash. I wouldn't trust one today after the structure has aged, lots of foam in one. I also wouldn't fly fast or pull hard in one. I'm also married and can find much better toys than what you were looking at. Scott "OneSkyDog" wrote in message ... The factory test pilot was killed when a wing folded. There was some issue about the spar. Regards, One Sky Dog |
The Goldwing spar was made stronger after that Crash.
I built up 3 sets of wings and others. Sold 12 Kits. Their have been many aircraft wings spars, built for other aircraft using that type of spars style. The other crashes of other Goldwings, were from pilot error. All of these first spars were called back. My Goldwing #36 was the updated wing. Still have it in the Hanger. Put about 60 hrs on it. Any type of aircraft will last forever, IF IT IS STORED IN THE RIGHT CONDITIONS. I build Many Composite planes full time since 1980. My Goldwing sure draws attention when doing a flying-bye. I had the first kit built Goldwing on display at Oshkosh Fly-In. Larry Fitzgerald |
I just spoke with a fellow named Art last night. He lives in Pacific Grove
and owns the last of the inventory. He was very kind and explained some of the issues with the Goldwing. He mentioned the spar mod but didn't remember when the mod took place. This Goldwing has a serial number of 170 and may have the updated spar. He mentioned what the spar would look like if it is the correct one. I haven't yet wandered out to the shed to look. At any rate, he was very complementary about the Goldwing, so maybe I'll find a builder to complete this one. Someone down in Fresno is interested and I think I'll put him in contact with Art and let the two yak at each other. This Goldwing has been stored very well as the foam for the wings is still quite pliable rather than crumbling. There may be hope for another one yet. I have reconsidered chopping it up for the time being. Dale Alexander "Fitzair4" wrote in message ... The Goldwing spar was made stronger after that Crash. I built up 3 sets of wings and others. Sold 12 Kits. Their have been many aircraft wings spars, built for other aircraft using that type of spars style. The other crashes of other Goldwings, were from pilot error. All of these first spars were called back. My Goldwing #36 was the updated wing. Still have it in the Hanger. Put about 60 hrs on it. Any type of aircraft will last forever, IF IT IS STORED IN THE RIGHT CONDITIONS. I build Many Composite planes full time since 1980. My Goldwing sure draws attention when doing a flying-bye. I had the first kit built Goldwing on display at Oshkosh Fly-In. Larry Fitzgerald |
Dale
All Spars were called back for the change. My number 36 and all spars after that had the Update. So don't worry about it. I still have a wing kit in my shop for sale. If the Engine is CDI, Let me know, I was at their shop in Jackson, Ca.and knew the owners back then. The one big problem flying a Goldwing, was its VERY light wing loading. If a Sparrow bird, flew accross your flight path in front of you, You would feel its tuberlance. I have flown it in some ruff wind. It is like all Canard aircraft. Twice the runway take off length, for lift off, compared to regular Conventional aircraft. Its like most ultralights. Fly in early morning or late eveing with no wind. Larry Fitzgerald |
Larry,
You are correct. I checked the spar and it does have the additional tubing. Looks like a pretty neat job too. I found out that Craig Catto was one of the original people at the factory. That's kinda neat. I have one of his props for my Velocity and his shop is about 2 1/2 hours south of where I'm at. I may have to call him and shake some cobwebs out of his neural pathways and see what interesting stories he has. Without the proper pullers, I can't tell what type of ignition it has. There is a flywheel bell mounted behind the pull start assembly and a pair of small black Bosch coils are mounted below the carb for whatever that is worth. Dale Alexander "Fitzair4" wrote in message ... Dale All Spars were called back for the change. My number 36 and all spars after that had the Update. So don't worry about it. I still have a wing kit in my shop for sale. If the Engine is CDI, Let me know, I was at their shop in Jackson, Ca.and knew the owners back then. The one big problem flying a Goldwing, was its VERY light wing loading. If a Sparrow bird, flew accross your flight path in front of you, You would feel its tuberlance. I have flown it in some ruff wind. It is like all Canard aircraft. Twice the runway take off length, for lift off, compared to regular Conventional aircraft. Its like most ultralights. Fly in early morning or late eveing with no wind. Larry Fitzgerald |
Hi Larry
Do you still have a wing kit in my shop for sale.? Regards Harry Quote:
Thai
Have a wing precut foam kit and spar is still in the shipping tube. From another kit have a basic fuselage frame, never started to build. Have a Goldwing with 60 hours on it. Its been in a hanger storage for many years. Had it at Oshkosk a couple times in early 1980's. Contact me on the new E-Mail My old web site is www.fitzair.net Larry Fitzgerald ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~ Thai Harry wrote: Hi Larry Do you still have a wing kit in my shop for sale.? Regards Harry Fitzair4 Wrote: Dale All Spars were called back for the change. My number 36 and all spars after that had the Update. So don't worry about it. I still have a wing kit in my shop for sale. If the Engine is CDI, Let me know, I was at their shop in Jackson, Ca.and knew the owners back then. The one big problem flying a Goldwing, was its VERY light wing loading. If a Sparrow bird, flew accross your flight path in front of you, You would feel its tuberlance. I have flown it in some ruff wind. It is like all Canard aircraft. Twice the runway take off length, for lift off, compared to regular Conventional aircraft. Its like most ultralights. Fly in early morning or late eveing with no wind. Larry Fitzgerald -- Thai Harry |
BEACH BOY ULTRALIGHT PLANS | Tony Shennan | Home Built | 0 | January 8th 04 01:58 AM |
Ultralight costs | Bob Martin | Home Built | 1 | January 1st 04 09:34 PM |
Ultralight Plans | Anubis | Home Built | 1 | October 20th 03 02:09 AM |
PLANS BEACH BOY ST-II ULTRALIGHT | tony | Home Built | 0 | October 10th 03 07:50 AM |
Ultralight magazine August 1981 | Gilan | Home Built | 0 | July 20th 03 04:34 AM |
