"Koopas Ly" wrote:
The only time that fuel is set to one particular tank is on the ground. I've never used fuel from only one tank in flight. Why would someone do that? Cessnas have the notorious characteristic of not drawing fuel evenly from both tanks in the Both position. This can result in fuel imbalance. In a Cessna 172 you might never notice any difference in the flight characteristics, but in a 182 which has more fuel capacity in each wing than the 172 has in total, you can develop an imbalance which becomes fairly uncomfortable. By selecting one tank or the other, you can burn fuel (mostly) from the full tank in order to reestablish lateral balance. I rent the aircraft I fly. Several times the previous renter wrote a squawk stating: "Fuel gets used only from left/right tank.". Thus far it turned out that they could not fly coordinated... Nevertheless, whenever I see this kind of squawk, I select left tank to taxi, right tank for runup, both tanks for takeoff. After having reached sufficient altitude, I fly for several minutes first on the left tank, then on the right. If this works oke, there is nothing amiss with the fuel feed. Of course, if it turns out there IS a problem, I can select the other tank (or both) and return with sufficient fuel. Beter to find out early than discovering later in the flight one of the tanks does not feed at a moment I do not expect it and possibly at a point which is a bit awkward. |
| Thread Tools | |
| Display Modes | |
| F-104 in Viet Nam Question | Don Harstad | Military Aviation | 2 | August 28th 04 09:40 AM |
| Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 06:31 PM |
| IFR Checkride Checklist | BTIZ | Instrument Flight Rules | 0 | April 18th 04 01:06 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
| Tanks for nothing (repost from Bearhawk list) | Del Rawlins | Home Built | 0 | August 6th 03 04:06 AM |
