"Tanks on both" checklist item
Old December 5th 03, 02:19 AM
Dan Thomas
"Tony Cox" wrote in message thlink.net...
"Koopas Ly" wrote in message
om...
The only time that fuel is set to one particular tank is on the
ground. I've never used fuel from only one tank in flight. Why would
someone do that?
Some models of 172 *require* you to select a single tank
above 5000', due (supposedly) to vapor lock problems.
Check your POH.
Lots of old pilots didn't trust fuel gauges, which is still a
wise attitude. They'd sometimes fly on one tank until it ran dry and
the engine quit, then switch to the other and know exactly how much
they had left and how much they'd burned. This doesn't work well if
the tanks are very far off the airplane's centreline, as the imbalance
can require increases aileron input, causing more drag and tiring the
pilot. It can also panic passengers and create unpleasant cabin odors
and extra janitorial work after the flight.
Dan
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 09:40 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 06:31 PM
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 01:06 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
Tanks for nothing (repost from Bearhawk list) Del Rawlins Home Built 0 August 6th 03 04:06 AM
