On Wed, 31 Mar 2004 23:09:43 GMT, "x" wrote:
"Corky Scott" wrote in message ... On Wed, 31 Mar 2004 19:51:59 GMT, "x" wrote: Anyone care to comment on using one of MT's composite blade props with electric pitch control? Eggenfellner seems to really want you to use this prop with his Subaru setup. I'm a bit concerned both with a composite prop and an electric pitch control. I don't think there's anything wrong with a properly made composite prop, and MT is one of better known prop manufacturers. They make LOTS of props, many of them for certified airplanes. What's your specific concern? Corky Scott I don't know anything about using composite construction for a propeller. I do know a little about fiberglass and carbon fiber composite, just from an "educated layman" point of view. So bearing that in mind, I would be worried about: 1) Would continual flex/unflex cause fatigue and how would you detect it if it's internal? (I think in the research environment they basically CAT scan parts to look for internal fatigue?) 2) How could you tell a trivial rock ding from a potentially disastrous one (again, hard to see what's inside)? Again, I'm not all all claiming these things happen, I just am asking if people know of any gotchas. Of course, there are lots of testimonials that basically say "I've had mine for X years and it hasn't broken yet", but that's not really data. There are a number of businesses making composite props in the world today, some of them making props for extreme aviation endeavors. MT and Hoffman make composite props that are used in unlimited aerobatic competitiions. In the world of props, metal props are the most dangerous in that they can and do vibrate in sympathy with the engine harmonics and can rapidly fatigue and fail. Some conditions are so dangerous that the airplane/engine/prop combination has a plackard requiring that the pilot avoid operations at a specific rpm. Wooden props are at the other end of the spectrum, they actually deaden vibrations. Composite props are somewhere in between those two extremes. MT and Hoffman are big time players in the world of certified and experimental props, and their prices reflect that. Secondly, does the electric system work automatically (so that you don't do anything), or is there a control that works like manifold pressure (i.e. "governed" so that changes in RPM cause automatic changes in blade pitch), or is there just a blade pitch control? Why would it be better/worse than hydraulic? Does anyone out there have one who can ring in on this? Electrically controlled props may or may not also be governed. Some just adjust pitch, others adjust pitch and govern rpm. If you have an electric adjustable prop in mind, the best thing to do would be to ask the vendor what it's designed to do. Corky Scott |
| Thread Tools | |
| Display Modes | |
| turbine propeller | sebastian | Home Built | 19 | March 21st 04 01:47 AM |
| Warp drive or other ground adjustable props | Wallace Berry | Home Built | 0 | March 10th 04 05:02 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| ALTRAK pitch system flight report | optics student | Home Built | 2 | September 22nd 03 12:49 AM |
