Peter R. wrote:
BTW, the DC9 ahead of me took at least three quarters of the runway to lift off, then turned left. When I departed, I dropped a notch of flaps to lift off very quickly, climbed a few hundred at Vx as per the obstacle DP, then turned the 90 degrees right as per the instruction to be well away from the previous two aircrafts' wake turbulence. Not answering your actual question about the clearance, but for what it's worth, I would not have tried to climb out at Vx. You have no hope of outclimbing a jet, and might want some additional airspeed if you hit a wake. Instead, I would have requested an early turnout and started my turn when I was 100' or 150' up. If they couldn't give me the early turnout, I would have refused the takeoff clearance. I'd be interested to know what others would do. -- David Rind |
| Thread Tools | |
| Display Modes | |
