Ground plane
Old July 16th 03, 04:17 AM
Frank
Default Ground plane
Can any one tell me how much signal I will lose if the ground plane is not
directly under the radiating element? What if I have to move it 2' away,
although still tied to co-ax shield?
Old July 16th 03, 04:20 AM
frank
Two FEET? Leave it on the ground. It will do as much good.
Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres.
Cyberchapter EAA Tech. Counselor http://www.rst-engr.com
Thanks {:-(
x-- 100 Proof News -
http://www.100ProofNews.com
x-- 3,500+ Binary NewsGroups, and over 90,000 other groups
x-- Access to over 800 Gigs/Day - $8.95/Month
x-- UNLIMITED DOWNLOAD
Old July 16th 03, 04:41 AM
Jim Weir
Impossible to say. Eighth of an inch, probably not a lot. Quarter of an inch,
measurable. Half an inch, Very noticeable.
Frank
-Can any one tell me how much signal I will lose if the ground plane is not
-directly under the radiating element? What if I have to move it 2' away,
-although still tied to co-ax shield?
Old July 16th 03, 12:50 PM
Scott
What good is a ground plane??? An air plane is much more fun Sorry,
couldn't resist...
Actually, what kind of installation are you planning that would elevate
the antenna above your ground plane? Is it a composite airplane and you
plan to put an antenna on the vertical stab top or something and the
ground plane laid into the composite on the turtle deck or something?
Hey Jim (Weir)...isn't that idea something similar to a Ringo Ranger II
(I have several) where the "ground radials" are connected via a piece of
coax that I believe is about 1/2 wavelength long?
Scott N0EDV
http://corbenflyer.tripod.com
http://groups.yahoo.com/group/ParasolAirplanes
Building RV-4
Gotta Fly or Gonna Die!
Old July 16th 03, 04:22 PM
Ron Natalie
"Scott" wrote in message ...
The Ringo Ranger isn't a quarterwave. The whiskers on the bottom of
it aren't for the same purpose as the quarterwave groundplane. They're
primarily there to keep the feedline from radiating.
Old July 26th 03, 12:52 AM
Frank
Scott wrote in
Sorry, couldn't resist...
elevate the antenna above your ground plane? Is it a composite
airplane and you plan to put an antenna on the vertical stab top or
something and the ground plane laid into the composite on the turtle
deck or something?
II (I have several) where the "ground radials" are connected via a
piece of coax that I believe is about 1/2 wavelength long?
Actually I was thinking of using the sruts for a ground plane, but did not
want the antennae in the middle of the seat, nor exposed on the outside of
the AIRPLANE.
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 February 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 04 07:27 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
