"Cliff" wrote in message ...
I have a KMA20 installed with 2 KX175B's. Where do I set the AUTO,COM1,COM2 toggle and rocker switches? I do have a 4P intercom and speakers. I would like to set COM1 as primary and COM2 on 121.5 for monitor. Thanks Cliff Hi Cliff, The toggle/rocker switches control which radios you listen to. The circular selector knob controls which radios you use for transmit. Let's take them one at a time. If you want to transmit on the radio that is wired as #1, then turn the selector knob to COM1. Select COM2 to transmit over the #1 radio. For receive, there is a selector for COM1, COM2, NAV1, NAV2, ADF, etc. The toggle switches typically have three positions. You can turn them ON or OFF. If you select AUTO, then you will be listening on the same radio that is selected for transmit. Therefore, if you set both COM1 and COM2 for AUTO, then tune two frequencies in the two radios, you can switch back and forth by using the transmit select knob. If you want to be on tower frequency, and also listen to ATIS, tune TWR frequency in #1, select COM1 for transmit, and set COM1 for AUTO. Tune the #2 radio for ATIS frequency, and use the toggle switch on COM2 for ON. You will hear both ATIS broadcast, and also be able to listen to tower frequency. When you key the mic to talk, you are transmitting on Tower frequency. Similarly, if you want to stay on frequency, but also listen to confirm the identification of a Navaid, then do the same as described above. Instead of selecting the COM2 toggle on to monitor, instead select the NAV1, NAV2, ADF, etc. toggle on to listen to it. Hope this helps. Probably most trainer aircraft are missing the operating manual for the radios, and folks end up getting a verbal briefing on how to use it, or have to rely on intuition and experience with other equipment. Safe flying, Brian |
