Recording cockpit voices
Old January 22nd 04, 08:55 AM
Glenn Westfall
Default Recording cockpit voices
Does anyone know of any adapters or such that would allow hooking up
an audio recorder to record all cockpit communications? ie, both
transmissions to ATC and conversations to other passengers.
Thanks,
Glenn
Old January 22nd 04, 01:38 PM
John T
"Glenn Westfall" wrote in message
Assuming your aircraft has an intercom, you can make a direct-connect cable
using Gene Whitt's directions found he
http://tinyurl.com/36x3c
I typically use a portable intercom that has an audio out jack. I use a
patch cord to connect that to either my voice recorder or my video recorder.
Having the portable intercom handy also provides a battery-powered backup
for the plane's intercom (actually used in that capacity once).
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old January 22nd 04, 02:17 PM
Chuck
Thanks,
Glenn
Glenn,
Not an answer to your question, but are you in Ft. Worth?
Old January 22nd 04, 03:05 PM
aircraftpatchcord.com I think is where I got my cord, but then to get it to
work I had to replace one of the resistors in it with one of the size that
Gene Whitt used. I use a cheap Panasonic voice activated tape recorder that
will record at 1/3 speed so I can get well over 2 hours on one side of a 90
minute cassette.
Jim Burns III
Remove "nospam" to reply
Thanks,
Glenn
Old January 22nd 04, 04:33 PM
Ben Smith
cable
I've made one of these cables, and they work good. I don't mess with tapes,
though. I bought an Olympus DM-1 digital recorder.. With the included 64MB
Smart Media, it will record for 10 hours on best quality. Double that if
you get a 128MB card. (Which is the max you can use). It also plays back
MP3/WMA format music files too.
Here's a small .wav clip from one of my recordings:
http://tinyurl.com/2ycds
Ben
C-172 - N13258 @ 87Y
Old January 22nd 04, 07:21 PM
Ron Natalie
"Glenn Westfall" wrote in message ...
Get a small microphone from radio snack. Plug it in to the
tape recorder and stuff the other end into the ear cup of your
headset.
Old January 22nd 04, 09:26 PM
Andrew Sarangan
"Ben Smith" wrote in message ...
cable
I record all my flights with students using a tiny digital recorder. I
have a very simple system that works wonderfully. You don't have to
tap into the intercom system. It is so simple that I record every
single flight, whether it is useful or not. I have written an article
about the setup on my website.
http://www.geocities.com/asarangan/aviation (and click on Cockpit
Voice Recorders).
Old January 22nd 04, 10:07 PM
Gary Drescher
"Andrew Sarangan" wrote in message
om...
Voice Recorders).
That's pretty cool. Even more straightforwardly, if you have a spare
headset and intercom station, you can just give the recorder its own
headset, pressing the two ear pieces together with the recorder in between.
I think I'll try that next time I fly.
--Gary
Old January 22nd 04, 10:39 PM
Glenn Westfall
On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck"
Thanks,
Glenn
Glenn,
No...I am in Okinawa at the moment. I am from Southern CA.
Old January 22nd 04, 10:42 PM
Glenn Westfall
After I posted this message I started thinking about it. Would this
work? Plug in a headphone adapter that goes from the big size to the
small walkman size in an unused intercom jack. Run an extension cable
from the adapter to the mic in on a recorder or video camera. That
shoud do the trick correct? The headphone jack of aviation headsets
are standard size and can be converted to the smaller size.
On 22 Jan 2004 12:26:06 -0800, (Andrew
cable
Voice Recorders).
backup cockpit lighting Josef Burger Instrument Flight Rules 35 January 2nd 05 02:23 AM
Antonov vs Galaxy cockpit Emilio Military Aviation 13 July 2nd 04 07:15 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 06:32 PM
What are you guys using for cockpit lights these days? Stealth Pilot Home Built 6 December 9th 03 10:14 AM
FS DeHavilland Open Cockpit Chipmunk [email protected] Aviation Marketplace 0 October 14th 03 12:10 PM
