Engine "on demand" regulation??
Old January 22nd 04, 07:58 PM
Frode Berg
Default Engine "on demand" regulation??
Hi!
Just spoke to my mechanic, and he told me that there will be a new
regulation here in Norway for private aircraft that takes away the mandatory
engine replacement after approx 2000 hours.
Instead, an engine is allowed to run indefinately as long as the regular
maintenance is carried out at a sertified shop.
He said this is the way it works in the US. Can someone verify this, and
tell me, does anyone ever replace their engine if this is the regulations
apart from when having a total failure (fire and such..)
Also, what are the safety issues?
Does a new engine actually perform better?
He told me about a C177 that came to his shop from the US for overhaul
(change of a couple of sylinders +) and it had over 9000 hours on it's
engine...
I thought it was mandatory everywere to replace an engine after 2000 hours
(or whatever time on individual engines).
If this gets approved, it certainly is good news for us private operators.
Maybe a GNS430 is not so far reach anyway....(our engine is just over 2000
hours now...)
Thanks,
Frode Berg
Old January 22nd 04, 08:23 PM
Orval Fairbairn
"Frode Berg" wrote:
Hi!
That regulation applies only if the plane is used for commercial
operations. Privately-used planes can fly until the engine fails to pass
compression or oil consumption specs, or start making metal.
engine...
I doubt seriously that the C177 had 9000 hrs between overhauls. It
probably had at least four overhauls, but used the same cylinders and
crank. Most other parts, including the cam, valves, lifters and
followers were probably replaced at overhaul.
Not in the US!
Such regulations are the product of non-GA types writing the rules.
hours now...)
Old January 23rd 04, 12:16 AM
John Galban
"Frode Berg" wrote in message ...
Yes, that's the rule in the U.S. You can run your engine beyond TBO
if you're not for-hire. Usually, we don't wait for a total failure
before overhauling. I'm just about to run past TBO on my engine. My
AI and I have agreed on a regular program of oil analysis and careful
monitoring of temps and pressures for signs that the engine is
wearing. Of course, the first time that the engine needs any costly
work (like a new cylinder), that will immediately become overhaul
time. This engine has been rock-solid for the last 1300 hrs. that
I've owned it, so I expect to get a few hundred more before replacing
it. It puts off the $15K expense of an overhaul for maybe a year or
two, but not indefinitely.
Old January 23rd 04, 04:51 AM
G.R. Patterson III
That's the way it works for many aircraft. There are certain types of businesses
that have to have the engine overhauled at the service time specified by the
engine manufacturer, but others don't have to do so. Note that the engine is
usually overhauled. Few people replace an engine with a brand new one, and the
regulations don't require replacement with new. Many individuals who own aircraft
will continue to operate the plane until the engine starts to give signs of
wearing out. These signs would be things like using too much oil, oil fouling
the plugs, poor compression, and so on.
Older engines are more prone to failure. I've read, for example, that this is a
big problem with the Douglas DC-3 as new original engines can't be bought anymore.
An overhauled engine should perform as well as a new one, and some shops produce
engines which they claim are better than new.
engine...
It's possible for an engine to last that long if it were overhauled several times
during that 9,000 hours. It's highly unlikely that one would live that long without
an overhaul.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 23rd 04, 07:30 AM
Frode Berg
Hi!
Thanks for all replies.
When you say "overhaul", what does this imply?
Is it an engine change, or just a major visit to the shop going through
everything and changing whatever is needed?
Here, a major overhaul means dismounting the engine, sending it to Lycoming
(or continental) and putting a factory overhauled one back in.
This costs approx $20.000 + shipping (over $1200) + additional parts and of
course labour...
However, if "overhaul" means replacing a cylinder or two, inspecting
cranckshaft, changing magnetos adn plugs, and generally going through
everything, this is a complete different matter, and probably much cheaper,
no?
Thanks,
Frode
"G.R. Patterson III" skrev i melding
businesses
is
aircraft
of
fouling
is a
anymore.
produce
engine...
several times
long without
an overhaul.
George Patterson
said is
Old January 23rd 04, 12:48 PM
Bob Noel
In article , "Frode Berg"
Hi!
note: I'm not an A&P, so I might get some of the terms wrong.
At a minimum, "Overhaul" means disassembly, checking that
each part is within service limits, and reassembly. I think
there are also some parts that must be replaced whenever the engine
is disassembled.
Most people I know want an overhaul to new limits, where each
part is checked to make sure that it has the same dimensions
as a new part. Also, some overhaul shops replace some additional
parts with new because their experience is that doing so will
reduce problems down the road.
When I had my engine overhauled, I didn't do an engine swap.
The engine only had ~2300 hours TT, so I had it overhaul to
new limits (and opted for new cylinders). A friend saved
time by doing ae engine swap.
Bob Noel
Old January 23rd 04, 04:05 PM
G.R. Patterson III
As Bob Noel says, they take the engine apart and make sure that every part meets
the specifications for reinstallation (the "service limits"). Some people prefer
to make sure that all parts meet the specifications for new parts. The key is
that this can be done by any competent mechanic; the engine does not have to go
back to Lycoming or Continental.
Shop policies also differ. When Lycoming overhauls an engine, they replace all
the cylinders and pistons with new ones. A local shop may recondition the old
cylinders and reuse them. A cylinder on something like an O-320 can typically
last 5,000 hours or so before it becomes risky to use it.
The bottom line is that getting an overhaul done by one of the major shops can
save you several thousand dollars over getting one done by Lycoming, and having
one done locally (called a "field overhaul") can save you even more. I've even
known some people to overhaul the engine themselves. This requires that a
certified mechanic oversee the work.
George Patterson
Old January 23rd 04, 07:00 PM
Orval Fairbairn
meets
prefer
go
all
can
having
even
That's the way i did my last overhaul. I had the cylinders ground .010"
oversize, installed all new bearings, valves, valve seats, pistons,
rings, lifters and followers, seals, etc. It is NOT rocket science! All
it really requires is the ability to use a torque wrench, common sense,
a source of parts.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
