Crosswind components
Old February 25th 04, 12:58 PM
Gary Drescher
"arcwi" wrote in message
Yes, but the common logic suggest that you also spend less time in
tailwind
that in head wind
Yes.
- and if there is no wind the two should cancell each
other...
No. Nothing makes them differ by equal amounts.
Consider the case when the headwind is equal to the TAS. Then it takes
*forever* to get to B.
Or consider a headwind that's just one knot less than the TAS. You
eventually get to B, but it takes an enormous amount of time. Even if the
trip back to A were instantaneous (which it isn't), it still couldn't cancel
out the extra time it took to get to B.
--Gary
Or should they...
"Stefan" wrote in message
arcwi wrote:
Can someone explain the difference?
You spend more time in headwind than in tailwind.
Stefan
Old February 25th 04, 11:19 PM
'Vejita' S. Cousin
Casey Wilson wrote:
(James L. Freeman) wrote in message
.com...
Can someone offer a non-mathematical EXPLANATION (as opposed to
DESCRIPTION) of why the speed of headwind and crosswind components of
a wind add up to more than the speed of the wind?
I'll give it a go (use to tutor math in college but that was a while
ago ^_^). This works best with pictures but here's teh basic outline.
Imgine you have a block on the floor. Two guys (A and B) are going to
push on the block. Since we're doing this wihtout pictures let's imgine
you're looking at the block from teh top down and it can go
North/south/east/west over teh floor.
1. A pushes on the south side of the block with 5 units (of whatever), B
pushes on the south side of the block with 5 units of force. The result
the block moves to the north with 10 units of force.
2. A pushes on teh south side of the block with 5 units, B pushes on the
north side of the block with 5 units. Result, teh block doesn't move at
all. But Both A & B are pushing with 5 units.
3. A pushes on the south side of teh block, B pushes on the east side f
teh block. Result is the block moves north-east.
That sounds ok right? But wait a mintue, in example 3 if only A was
pushing then the block would move north and only north. And if only B was
pushing the block would move east and only east. The block moves
north-east because both are pushing.
In example 2 the block didn't move at all, because A and B are pushing
in opposite directions with equal force.
But What if A pushing on the south side of rh block with 10 units and B
pushes on teh north side with 8 units? Well the block would move north,
at 2 units ofr force.
From the blocks POV having A push from teh south at 10 & B push from
teh north at 8, is THE SAME THING as just having someone push at 2 units
of force.
This is know as vector addition. You need to take teh scaler (number
of units of push) and the vector (direction) into account to do vector
addition.
So if I told you that A was pushing at 10 units and B was pushing at 10
units, and asked what direction is the block moving what would you say?
Well you 'should' say "I don't kow." Because you don't know what
direction A and B are pushing.
The above examples are easy because A nd B are pushing in opposite
direttions. It's a little harder to think of it when A and B push between
0-180 degrees. The math is easy (sin/cos stuff or use a cross wind
diagram). It's the same thing thou.
Let's say you want to land on runway 36 (to make life easy). The wind
is 045 @ 20. Well just like teh block having the win at 045 @ 20, is the
same as having two winds that are pushing the plane at the same time.
One wind is coming from 360 and the other from 090, the end result is a
single wind from 045 (yes I know wind doesn't work like that work with me
here).
The reason we 'spilt the wind up' is because the 'peice' of wind coming
from 360 doesn't concern us, but that peice from 090 does, as it'll blow
us off course when landing.
So it's the reverse of the block examples, we have one force at some
odd angle, and we spilt it into two force: head wind and cross wind.
Because these forces have strength (number of units) and direction (in
this case 045) we can't just add/subtract like number.
Just like the block example above where the block was moving forward at
2 units, wind acts the same. Landing on 360 with a wind from 360 @ 10 is
all head wind, 015 @ 10 a little cross wind, 080 @ 10 almost all cross
wind.
So the cross wind component varies with direction, and you can't just
add/subtract the units to get there. Now find any url about trig and look
up sin and/or cos and this will make a lot more sense (I hope). But you
asked why and not how to calculate it
This stuff is actually pretty easy to do if you have a scienctific
calculator. Sorry the above is so long ...
Old February 25th 04, 11:50 PM
'Vejita' S. Cousin
arcwi wrote:
That's simple - it's a vector sum. But can someone explane this to me:
Scenario One
An aicraft is flying from A to B, TAS=200 Kts, Distance AtoB=100nm, Wind
blowing from B to A with a speed=100Kts
Everyone should be able to claculate that GS(A-B)=100 Kts and GS(B-A)=300
Kts , therefore round trip time A-B-A=60min+20min=1hr20min
Scenario Two
Same as One, but remove the wind completely. The GS in both cases = 200 Kts,
therefore round trip time A-B-A = 30min+30min = 1hr
I just wrote a long reply about how vectors sort of work. Not sure if
this helps or not (as I'm not 100% sure of the question you're trying to
ask but...).
Break it down a bit more. Thing of Scenario 1 as two trips:
A-B, flying at 200kts into 100kts head win, gs = 100kts. Distance is
100kts. 100/100 = 1hr
B-A, flying at 200kts with 100kts tail wind, gs = 300kts. Distnace is
100kts. 100/300 = 20min (1/3 of an hour)
Total time 1:20
Scenario 2:
A-B, flying at 200kts no wind. Distance is 100kts. 100/200 = 30 min
B-A, flying at 200kts no wind. Distance is 100kts. 100/200 = 30 min
Total time 1hr
Here's teh take home message, wind ALWAYS slows you down (round trip).
And you spend more time flying with a headwind than a tail wind(it's not
50/50 ^_^).
Old February 26th 04, 12:40 AM
nuke
Common logic fails here, because the the commonsense explanation that the
upwind and downwind differences ought to cancel out only works if the
relationship is linear. If you do the math, the relationship between the
round trip time, round trip distance, TAS and wind speed is nonlinear:
time = distance/speed
round trip time = time out(upwind) + time back(downwind),
= D/(T - W) + D/(T + W), where D = leg distance, T = TAS, W = windspeed
= [D(T + W) + D(T - W)] / [(T - W)(T + W)], using x/y + z/w = (xw + yz)/yw
= (DT + DW + DT - DW) / (T^2 - TW + TW - W^2)
= 2DT / (T^2 - W^2)
2D is the round trip distance, so in words: round trip time = (round trip
distance x TAS) / (TAS^2 - windspeed^2)
[As a check, this reduces to: round trip time = round trip distance / TAS,
when windspeed = 0]
Hence the relationship is nonlinear with respect to wind speed. That isn't
normally so obvious because usually TAS wind speed. It's more obvious in
the original post because the poster chose a wind speed much closer to TAS.
[Work it out for windspeed = 10 kt and the other data in the original post,
and the upwind and downwind differences do almost cancel out. Then work it
out for windspeed = 199 kt!]
nuke
tailwind
that in head wind - and if there is no wind the two should cancell each
other... Or should they...
Stefan
Old February 26th 04, 02:07 AM
Casey Wilson
"James L. Freeman" wrote in message
om...
Thanks.
I'm not sure where James's question was going, but here is an example as I
just copied it minutes ago from:
http://www.edwards.af.mil/weather/index.html
02/25/2004 16:57 LCL Rwy 4 Wind 216 Deg at 2 Kts Cross Wind 4 Kts
Note the runway crosswind is reported higher than the wind velocity. I would
be delighted if someone could explain this -specific- condition.
Old February 26th 04, 02:22 AM
Teacherjh
It's an error. It might be because the winds and the runway crosswind were
measured at different points, or at different times, or because of errors in
the math (roundoff several times?). Mathematically, the crosswind cannot be
greater than the total wind.
Jose
(for Email, make the obvious changes in my address)
Old February 26th 04, 03:06 AM
karl
Same as a sailboat.
Can go much faster than the wind.
Karl
Old February 26th 04, 03:43 AM
Teacherjh
Same as a sailboat.
Actually, sailing is different because of the interaction of the keel and the
water. You can't go faster than hull speed, but ignoring that you could
theoretically go faster than the wind, if you were going at 90 degrees to it.
You can even sail INTO the wind.
You can't, however, run before the wind faster than the wind (unless you have
one humongus current)
Jose
Old February 26th 04, 02:28 PM
John T Lowry
Try a "continuity" argument: A pushes on the (now CYLINDRICAL, with axis
vertical) block (silo), from the South, with 10 units of force. B initially
pushes from the North with 10 units. Result, 0 net force on the block. But
now let B move off to the East somewhat (to his left) and push, again (and
always) with force 10 units. Net force then has small components to the West
and North. Now let B move farther to his left. Larger components to West and
North. By the time B has moved around to the Southeast, the net force will
have large components to the North and considerable to the West. If B moves
into A's postion, the net force will be 20 units to the North. By
continuity, the net force increases continuously from 0 to 20. So at some
point that force will start exceeding 10 units (and stay that way).
John
John T Lowry, PhD
Flight Physics
5217 Old Spicewood Springs Rd, #312
Austin, Texas 78731
(512) 231-9391
"'Vejita' S. Cousin" wrote in message
.com...
of force.
addition.
here).
wind.
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 03:56 AM
