Damaged Certified into Homebuilt?
Old May 16th 04, 05:38 AM
On Sun, 16 May 2004 01:38:18 GMT, Ron Wanttaja
On 15 May 2004 15:48:06 -0700, (Ben Haas) wrote:
David O wrote in message . ..
The FAA Aircraft Registration database lists about four hundred Cessna
aircraft currently registered as Experimental. Of those, only the
following 14 Cessnas are registered as Experimental Amateur Built.
OK Cy and Roger, Explain these??? A curious mind wants to know..
Probably mostly errors in the database. Take N817BR, for instance. Listed
in my January 2004 database as Experimental/Amateur-Built Boeing B-17
Flying Fortress. Or like N484A, a Sea Rey licensed in the Normal category,
as are Sonerai N5102Q, Quicksilver N184DH, and Volksplane N2312B. I don't,
for the least minute, think anyone went through the certification process
on these.
The FAA Registration database has a Certification column (which indicates
how the plane was licensed) *and* an "Amateur-Built" column. Airplanes
like that B-17 are listed as "Experimental Amateur Built" in the
certification column yet have the "Amateur" flag turned off. There are 242
airplanes of this sort, from practically every manufacturer.
Things go around the other way, too. There are over 6,000 airplanes on the
January 2004 registry that have the Amateur-Built flag set, but are NOT
certified as "Experimental Amateur-Built." According to the FAA's
database, there are over 150 "Amateur-Built" Gulfstream 5s.
So: Don't rely too much on what the FAA registration database says.
But it *is* possible to get production-style airplanes certified as
Experimental Amateur-Built. I mentioned a Cessna 150 owner on a previous
posting, and realized that there is a Stinson 108-3 in the same situation
at my home field.
The owners either pulled strings with friends at the FAA or performed such
a massive rebuild that the inspector probably agreed it met the 51% rule.
Remember the guy I mentioned who had his 150 Ex/Am...he did NOT want any
publicity. He probably worked his via a buddy at the FAA. The Stinson guy
doesn't want to talk about his, either, but this plane has, at least, some
obvious external changes.
So: Is it possible? Yes.
Can a person who has no aircraft design, construction, or maintenance
expertise manage it? I'd say, no.
There is a "rebuilt" Cessna 140 here in Ontario that has been totally
remanufactured and registered as a homebuilt - but is not registered
as a Cessna and has a new serial number assigned by the current
"manufacturer". It is a Cessna in everything but name - but the owner
is allowed to do all maintenance, and use non certified parts.
The plane did NOT qualify for OM, apparently - and as an OM would not
be allowed to fly in the USA, even with a letter of permission - while
a Canadian homebuilt/amateur built can be.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
