Ballistic parachutes with pushers
Old May 16th 04, 07:14 PM
Occom
"anonymous coward" wrote in message
news
Would I be right in assuming that ballistic parachutes and pusher props
don't go?
Thanks,
AC
That does not make sense to me, how would you arrive at such a conclusion?
Old May 16th 04, 07:34 PM
anonymous coward
news
don't go?
Thanks,
AC
I was worried there might be a possibility of the parachute or its bridle
getting caught in a pusher propellor - especially during deployment.
The sort of designs I had in mind were the LongEZ or Junqua IBIS. I can
see there probably isn't any problem with most flexwing microlight designs.
AC
Old May 17th 04, 01:35 AM
nauga
anonymous coward wrote...
The sort of designs I had in mind were the LongEZ or Junqua IBIS...
There are clearly slow-speed pushers with ballistic chutes, as I
think you knew based on some stuff I snipped. On a Long-Eze I'd be
more concerned about canopy/shroud strength and maximum deployment
speed rather than prop fouling. I'd bet adding a chute to a
fast cruiser where it wasn't designed in from the start would
either add a significant amount of weight in terms of additional structure
and heavy-duty chute or reduce cruise speed to something close to max
deployment speed. Or maybe just panacea or severely restricted
utility.
Dave 'strop size' Hyde
Old May 17th 04, 11:36 AM
anonymous coward
I'd been wondering the same. On hang-gliders the parachute is
attached to the pilot and not to the aircraft, so provided the pilot can
stand the opening shock it doesn't matter what happens to the wing - I
wonder if the answer is to attach the bridle to the pilot's seat rather
than the airframe.
AC
Old May 17th 04, 01:04 PM
nauga
I wonder if the answer is to attach the bridle to the pilot's
seat rather than the airframe.
http://www.martin-baker.co.uk/
Someone in Russia (Zvezda?) was marketing a lightweight
ejection seat for GA a while back. Dunno if they're
still around.
Dave 'back to the taxpayers' Hyde
Old May 19th 04, 12:28 AM
Dillon Pyron
On Mon, 17 May 2004 10:36:04 +0100, anonymous coward
than the airframe.
The Air Force and Navy do that. They call it an ejection seat. :-)
dillon
When I was a kid, I thought the angel's name was Hark
and the horse's name was Bob.
Old May 16th 04, 08:04 PM
Mike Patterson
On Sun, 16 May 2004 17:14:37 GMT, "Occom"
news
don't go?
Thanks,
AC
I assume he's thinking that when you deploy the 'chute the plane will
tend to tip nose-down, risking the 'chute getting fouled in the prop.
Do I get a prize? :-)
Mike
Mike Patterson
Please remove the spamtrap to email me.
Old May 17th 04, 11:27 AM
anonymous coward
news
don't go?
Thanks,
AC
I'm not sure, I'll have to ask the quizmaster. My reasoning is mostly
visual and may be wrong, but it goes something like this...
To deploy, a parachute has to be in-line with the direction of motion of
whatever it's slowing down. As counterexamples, if you were in a 'plane
and shot a ballistic parachute forward I imagine it would get swept back
over the canopy without opening. If you shot it upwards or sideways it
wouldn't open until it was swept back behind the aircraft, because there
would only be lateral airflow with respect to the canopy.
This is assuming the aircraft is moving forwards, which I guess it may
well not be... But the problem I envisaged was dynamic rather than
static-ish. When the canopy is open and the plane descending, I guess
whether it's nose down or tail down or level just depends on the
positioning of the attachment point.
AC
Of parachutes and things ShawnD2112 Aerobatics 34 July 21st 04 07:13 PM
Ballistic chute saves 4 souls Bob Babcock Home Built 28 April 27th 04 10:29 PM
Parachutes for sale Ken Ibold Aerobatics 0 September 23rd 03 06:39 PM
virgins (was: Question - Regarding Canard Pushers...) RobertR237 Home Built 1 August 11th 03 12:06 AM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 12:07 PM
