which frequencies are all?
Old April 8th 04, 02:45 PM
Arden Prinz
Default which frequencies are all?
I was approaching class C airspace for landing at the primary airport
for which the class C airspace is designated and I listened to the
ATIS. The ATIS said "all frequencies are combined on
TowerFrequency". So I tuned to TowerFrequency and made my radio
call to approach. The response that I got was that I needed to call
approach on the approach frequency. So, I guess that begs the
question ... when the ATIS says "all frequencies are combined", which
frequencies are included in "all frequencies"?
Thank-you in advance.
Old April 8th 04, 03:32 PM
Ryan
I would have done the same thing. Maybe it meant only if you were landing
in the Class C.
"Arden Prinz" wrote in message
om...
Old April 8th 04, 05:06 PM
Steven P. McNicoll
om...
my radio call to approach. The response that I got was that I
needed to call approach on the approach frequency. So, I guess
that begs the question ... when the ATIS says "all frequencies are
combined", which frequencies are included in "all frequencies"?
Based on the tower's reply, it appears "all frequencies" means tower, ground
control, and clearance delivery frequencies. But that doesn't mean your
assumption was unreasonable.
Old April 8th 04, 05:07 PM
Steven P. McNicoll
"Ryan" f wrote in message ...
were landing in the Class C.
He was.
Old April 8th 04, 05:17 PM
Otis Winslow
One controller was running all those positions perhaps?
om...
Old April 8th 04, 05:22 PM
Neil Gould
Recently, Arden Prinz posted:
I would have presumed it meant exactly as you did. Out of curiosity, what
happened next? Did they give you the approach frequency, change the ATIS,
or did you get the same controller when you changed frequencies?
Neil
Old April 8th 04, 05:43 PM
TaxSrv
tower, ground
your
A solution requiring no thought is just call approach per normal, and
switch to further freqs as instructed or to just "stay with me," as
happened to me once at big Milwaukee apt at 5AM, from 30 miles out to
all the way to shutdown.
I you happen to know the same guy has been working twr and ground,
after startup, wouldn't you still call on ground freq? Otherwise,
you're setting yourself up for embarrassment if 10 seconds prior, the
ground controller returned from the can, and both positions are back
to normal. Correct?
Fred IF.
Old April 8th 04, 06:15 PM
Tony Cox
nk.net...
om...
ground
It seems like a misleading ATIS instruction. I've often heard
"Clearance and Ground combined on xx.xx" but never "all
frequencies".
Some pilots - especially newly minted ones - don't realize and
don't really have any reason to suspect that different functions
are handled at different facilities. Publications like "Pilot Guide"
add confusion by listing ATIS, Approach, Tower & Ground in
little boxes for each airport. Who, without extra knowledge, would
suspect that "Approach" is handled by a different facility?
Arden's question isn't easy to answer anyway. If I were approaching
Monterrey (MTR), class C, approach is handled by a facility in
the tower on the floor below the guys looking out of the window.
If I heard "all frequencies" from MTR, I'd assume it means approach
too.
Old April 8th 04, 07:08 PM
SFM
Tower, ground, and clearance delivery. ATIS is for the airport you listening
to not approach control
Scott F. Migaldi, K9PO
MI-150972
PP-ASEL-IA
Are you a PADI Instructor or DM? Then join the PADI
Instructor Yahoo Group at
http://groups.yahoo.com/group/PADI-Instructors/join
Catch the wave!
www.hamwave.com
**"A long time ago being crazy meant something, nowadays everyone is
crazy" -- Charles Manson**
om...
Old April 8th 04, 07:58 PM
Ben Jackson
TowerFrequency".
I got the ATIS and Boundary Bay, BC (class D-esque, I forget if that
is actually class D in Canada). I was alert for the fact that they
had a new second tower frequency. The ATIS said "frequency blah blah
is now in use" so I call them on that frequency and they chastize
me -- the ATIS said "not in use". Raar!!
Ben Jackson
http://www.ben.com/
Scanner frequencies for Oshkosh? Greg General Aviation 1 July 21st 04 05:40 PM
Meaning of "IC" on KPHL Frequencies? [email protected] Instrument Flight Rules 2 April 26th 04 05:16 PM
Howie Keefe's Topo Atlas/WAC charts & frequencies Mark Piloting 10 December 1st 03 03:36 PM
Approach Control Frequencies John General Aviation 5 October 18th 03 10:30 AM
Approach Control Frequencies John Owning 10 October 5th 03 01:16 PM
