Jim Weir wrote: There was an AD several dozen years ago that affected [almost] all McCauley props. The idea was to fill the hub with red hydraulic fluid so that any leaks would be immediately apparent to the most casual observer. How long does such a prop last if it starts leaking in flight? I've seen people put up with grease-spitting props for a long time. Even fly it to the overhaul location. Doesn't seem like you can do that with oil. -- Ben Jackson http://www.ben.com/ |
| Thread Tools | |
| Display Modes | |
| PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 05:41 AM |
| Is there a minimum prop speed? | Jim Carter | Owning | 2 | June 29th 04 02:49 AM |
| Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 04:41 AM |
| Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 03:42 AM |
| Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 11:08 PM |
