A-65 Continental 100 Octane Valves: HELP!
Old February 14th 05, 12:57 AM
Cy Galley
You are confusing the C-75 to C-85 which indeed used a larger venturi and
Main jet. The A-65 to A-75 change was basically just a change in the red
line. No Carb changes. The Large end of the connecting rod had to be
drilled for a squirt hole and this was done on the later A-65 for longevity.
The RPM was boosted from 2300 to 2600 by using a flatter pitched prop. The
A-series Continental manual also recommends a slight timing change for the
upper plug to 29° and the lower to 32° The Carb venturi is the same 1.25
for both the A-65 and A-75
Cy Galley - Aeronca Aviators Club
Newsletter Editor & EAA TC
www.aeronca.org
Actively supporting Aeroncas every day
IIRC, the A75 had a slightly different carb venturi diameter and a
larger main jet in addition to the larger piston pin.
Dan
Exhaust Valves Boelkowj Home Built 4 January 25th 05 01:15 AM
Continental IO-520A operating data? Michael Owning 7 November 26th 04 09:38 PM
millenium cylinders and 80 octane R. Wubben Owning 7 March 13th 04 05:41 AM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 05:46 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 08:48 AM
