Constant speed props
Old June 28th 04, 10:30 PM
On Mon, 28 Jun 2004 10:39:31 -0500, Greg Copeland
I agree, common sense says, we'll see a happier engine resulting from
better managed temps, but is there anything that supports what a "happier
engine" translates into?
Greg
This will be extremely difficult to quantify, because if you've read
all Deakin's columns, you will know that he feels that both Lycoming
and Continental have lost the ability to put together a long lasting
engine any longer. Also, there is a URL out there that describes the
problems the parallel head Lycoming 6 cylinder engine has in terms of
producing too much heat at the exhaust valve guide due to improper
original design back when they began installing hydraulic lifters.
This last piece of information is not from a Deaking column, it's from
two AP's who have done EXTENSIVE research on the problem of 6 cyl.
parallel valve Lycomings and why they can't seem to make TBO without
loosing compression because of excessive valve guide wear.
These guys traced it to the lack of oil flow to the valve guide, it's
that simple. Other engines that have MUCH more flow to the exhaust
valve guide do not suffer the same excessive valve guide wear.
See: http://egaa.home.mindspring.com/engine1.htm
What Deakin HAS said, and frequently, is that there are no engine
development engineers at Lycoming anymore. They've all retired.
Lycoming doesn't manufacture it's own parts anymore, they just
assemble what's sent them from outside sources.
But they still charge you plenty for them.
Corky Scott
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 05:41 AM
Constant speed prop oil leak DP Piloting 23 April 21st 04 11:15 PM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 04:41 AM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 03:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 11:08 PM
