Running runup?
Old June 29th 04, 02:42 PM
Dave Stadt
"Henry and Debbie McFarland" wrote in message
link.net...
Do you do 'running' run-ups?
Yes. If you attend any of the major fly-ins your run-up will be a rolling
one.
Deb
1946 Luscombe 8A (His)
1948 Luscombe 8E (Hers)
1954 Cessna 195B, restoring (Ours)
Jasper, Ga. (JZP)
You can add skis and floats to the list that require run-ups on the move.
Old June 29th 04, 02:44 PM
AJW
I do NOT check prop and mags on my Mooney while running, because I want to
control my taxi speed w/o riding the brakes.
I've been known to do VOR checks and the like while taxiing, but unless your
checklist has items in a suitable order (hey, at 3000 hours, nearly all in the
same airplane, I still use a checklist) it's easier to overlook something if
you do a running run-up. Also, your head is inside the cockpit for those hmmm,
15 oor 20 seconds.
As for that guy who flys a seaplane? There's something even stanger about guys
who land on water than those of us who with our tail backwards (M20J).
Old June 29th 04, 02:55 PM
Jay Honeck
one.
Amen.
If you stop to do a "proper" run-up right before departing OSH (or SNF),
you'll have four FAA guys in pink shirts absolutely apoplectic, jumping up
and down and waving flags at you! "Rolling" run-ups are sometimes your only
option.
Many times the traffic gets backed up considerably, however, and you can
kinda cock the plane to the side, and do a "real" run-up. Of course, then
you get into the discussion of WHEN to do your run-up.
If you do a run-up in line, and it's five or ten (or 20?) minutes till you
depart, you've lost much of the utility of doing a run-up. Isn't the idea
to do the run-up as close to departure as possible, to ensure that the
engine and prop are functioning properly at take-off?
It's probably my own paranoia, but I try to do my run-up right before
fire-walling the throttle so that nothing else has a chance to break in the
meantime.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 29th 04, 05:03 PM
G.R. Patterson III
No.
George Patterson
None of us is as dumb as all of us.
Old June 29th 04, 06:38 PM
Dale
In article lk6Ec.1801$AI.68@attbi_s04,
Always. I fly from a turf field....stationary runup is bad for the
prop. Once rolling I come up to 1700 for the mag check, then back to
idle to control speed.....up to 2000 for a quick prop check. Being on
grass the speed doesn't become a big issue...no need to hold brakes
during the checks.
Dale L. Falk
Old June 29th 04, 09:29 PM
AJW
guys
And what makes you think the M20E or M20J has a tail on backwards? Don't
you know it's all those others that have it wrong :-))
Let's justy say those of us who drive Mooneys like our tail a little
differently than some others.
Old June 29th 04, 09:31 PM
AJW
during the checks.
Dale L. Falk
You do mean, don't you, referring to your sign off, subject to the limitation
"sith your clothes on"?
Old June 30th 04, 12:40 AM
Andrew Gideon
one.
I just checked out in a new (to me) club airplane. At some point, I was
taxiing and the CFI suggested I do something. I don't recall what it was,
but it wasn't one of the items that *must* be done while moving (ie.
checking for proper function of the AI, HI, and TC).
I reminded him that, if I did as he suggested with a certain other CFI in
the club for a checkout, I'd fail.
So I guess the right answer is "it depends".
- Andrew
C-182 carb-heat causing rough running. R.T. Owning 11 November 26th 04 11:50 PM
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 08:34 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 05:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 04:46 AM
