Winds on long runways
Old July 14th 04, 11:19 PM
Dale
"Maule Driver" wrote:
I'm thinking the adverse yaw would only work with downwind ailerons.
Averse yaw is caused by the drag of the down-deflected aileron.
Assuming you have the correct aileron position for the crosswind, the
drag of the down-deflected aileron will help counter weather-vane.
In the B-17 if you used the wrong aileron you would not have enough
rudder to counter it...the ailerons on that airplane produce a lot of
drag.
Dale L. Falk
Old July 15th 04, 03:12 AM
Maule Driver
Yep, I got mixed up.
"Dale" wrote in message
drag.
Dale L. Falk
Old July 15th 04, 03:32 AM
William W. Plummer
snip...
drag.
That's a bit strange. What is the "wrong aileron"?
Ailerons control roll, while the rudder controls yaw.
If you are "wing low" while approaching in a crosswind, it is possible
that the windward wing will dip and a spin will try to start. You need
to correct using the rudder, but if no more authority is available, you
have a problem. It's not specific to the B-17.
Old July 15th 04, 08:38 AM
Dale
In article I8lJc.83007$IQ4.42418@attbi_s02,
I'm referring to after you're on the ground...during rollout. I had a
"Captain" roll in the wrong aileron when the airplane began to turn into
the wind...things got pretty interesting for a bit. G
Dale L. Falk
Old July 17th 04, 07:09 AM
Jack
drag.
But not always, and not only. If you have an ASES rating you must be
familiar with the use of ailerons for steering on the surface. You also
should not overlook the necessity of using rudder to control roll in
high angle of attack on swept wing high performance aircraft, while
avoiding the use of ailerons.
Perhaps you are more familiar with the specific characteristics of B-17s
than is Maule Driver. If so, by all means tell us about it.
Do you notice the apparent contradiction between your statement in your
first paragraph and your claim in the second paragraph?
Jack
"Cave ab homine unius libri"
Old July 17th 04, 09:35 AM
Dale
In article , Jack
Which two paragraphs? mine or Maule Drivers? G
Dale L. Falk
Very long XC Story SFM Instrument Flight Rules 2 October 27th 04 04:08 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 04:02 PM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 04:02 PM
My First Time In Severe Turbulence (Long) David B. Cole Instrument Flight Rules 6 March 10th 04 11:21 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 08:51 PM
