sounds barrier speed limits
Old August 10th 04, 09:50 AM
Roger Halstead
Default sounds barrier speed limits
On Tue, 10 Aug 2004 06:48:46 GMT, "steve mew"
Does anyone know where the specific FAA regulations are that govern
supersonic flight ?
ie Hypothetically if one wanted to fly across the continental US at post
sonic speed how would you go about it ?
It's in the FARs, but my book is in the Deb.
As to the second question. Join the Airforce. There are only two
areas that I know of where civilan supersonic flight is permitted. One
over the gulf and the other in the south west. Neither connect and
none are transcontinental.
www.rogerhalstead.com
Old August 10th 04, 09:59 AM
C J Campbell
"steve mew" wrote in message
supersonic flight ?
Title 14: Aeronautics and Space
PART 91—GENERAL OPERATING AND FLIGHT RULES
Subpart I—Operating Noise Limits
§ 91.817 Civil aircraft sonic boom.
(a) No person may operate a civil aircraft in the United States at a true
flight Mach number greater than 1 except in compliance with conditions and
limitations in an authorization to exceed Mach 1 issued to the operator
under appendix B of this part.
(b) In addition, no person may operate a civil aircraft for which the
maximum operating limit speed MM0 exceeds a Mach number of 1, to or from an
airport in the United States, unless—
(1) Information available to the flight crew includes flight limitations
that ensure that flights entering or leaving the United States will not
cause a sonic boom to reach the surface within the United States; and
(2) The operator complies with the flight limitations prescribed in
paragraph (b)(1) of this section or complies with conditions and limitations
in an authorization to exceed Mach 1 issued under appendix B of this part.
(Approved by the Office of Management and Budget under control number
2120–0005)
§ 91.819 Civil supersonic airplanes that do not comply with part 36.
(a) Applicability. This section applies to civil supersonic airplanes that
have not been shown to comply with the Stage 2 noise limits of part 36 in
effect on October 13, 1977, using applicable trade-off provisions, and that
are operated in the United States, after July 31, 1978.
(b) Airport use. Except in an emergency, the following apply to each person
who operates a civil supersonic airplane to or from an airport in the United
States:
(1) Regardless of whether a type design change approval is applied for under
part 21 of this chapter, no person may land or take off an airplane covered
by this section for which the type design is changed, after July 31, 1978,
in a manner constituting an “acoustical change” under §21.93 unless the
acoustical change requirements of part 36 are complied with.
(2) No flight may be scheduled, or otherwise planned, for takeoff or landing
after 10 p.m. and before 7 a.m. local time.
§ 91.821 Civil supersonic airplanes: Noise limits.
Except for Concorde airplanes having flight time before January 1, 1980, no
person may operate in the United States, a civil supersonic airplane that
does not comply with Stage 2 noise limits of part 36 in effect on October
13, 1977, using applicable trade-off provisions.
Subpart K—Fractional Ownership Operations
Appendix B to Part 91—Authorizations to Exceed Mach 1 (§91.817)
Section 1. Application
(a) An applicant for an authorization to exceed Mach 1 must apply in a form
and manner prescribed by the Administrator and must comply with this
appendix.
(b) In addition, each application for an authorization to exceed Mach 1
covered by section 2(a) of this appendix must contain all information
requested by the Administrator necessary to assist him in determining
whether the designation of a particular test area or issuance of a
particular authorization is a “major Federal action significantly affecting
the quality of the human environment” within the meaning of the National
Environmental Policy Act of 1969 (42 U.S.C. 4321 et seq.), and to assist him
in complying with that act and with related Executive Orders, guidelines,
and orders prior to such action.
(c) In addition, each application for an authorization to exceed Mach 1
covered by section 2(a) of this appendix must contain—
(1) Information showing that operation at a speed greater than Mach 1 is
necessary to accomplish one or more of the purposes specified in section
2(a) of this appendix, including a showing that the purpose of the test
cannot be safely or properly accomplished by overocean testing;
(2) A description of the test area proposed by the applicant, including an
environmental analysis of that area meeting the requirements of paragraph
(b) of this section; and
(3) Conditions and limitations that will ensure that no measurable sonic
boom overpressure will reach the surface outside of the designated test
area.
(d) An application is denied if the Administrator finds that such action is
necessary to protect or enhance the environment.
Section 2. Issuance
(a) For a flight in a designated test area, an authorization to exceed Mach
1 may be issued when the Administrator has taken the environmental
protective actions specified in section 1(b) of this appendix and the
applicant shows one or more of the following:
(1) The flight is necessary to show compliance with airworthiness
requirements.
(2) The flight is necessary to determine the sonic boom characteristics of
the airplane or to establish means of reducing or eliminating the effects of
sonic boom.
(3) The flight is necessary to demonstrate the conditions and limitations
under which speeds greater than a true flight Mach number of 1 will not
cause a measurable sonic boom overpressure to reach the surface.
(b) For a flight outside of a designated test area, an authorization to
exceed Mach 1 may be issued if the applicant shows conservatively under
paragraph (a)(3) of this section that—
(1) The flight will not cause a measurable sonic boom overpressure to reach
the surface when the aircraft is operated under conditions and limitations
demonstrated under paragraph (a)(3) of this section; and
(2) Those conditions and limitations represent all foreseeable operating
conditions.
Section 3. Duration
(a) An authorization to exceed Mach 1 is effective until it expires or is
surrendered, or until it is suspended or terminated by the Administrator.
Such an authorization may be amended or suspended by the Administrator at
any time if the Administrator finds that such action is necessary to protect
the environment. Within 30 days of notification of amendnent, the holder of
the authorization must request reconsideration or the amendnent becomes
final. Within 30 days of notification of suspension, the holder of the
authorization must request reconsideration or the authorization is
automatically terminated. If reconsideration is requested within the 30-day
period, the amendment or suspension continues until the holder shows why the
authorization should not be amended or terminated. Upon such showing, the
Administrator may terminate or amend the authorization if the Administrator
finds that such action is necessary to protect the environment, or he may
reinstate the authorization without amendment if he finds that termination
or amendnent is not necessary to protect the environment.
(b) Findings and actions by the Administrator under this section do not
affect any certificate issued under title VI of the Federal Aviation Act of
1958.
[Doc. No. 18334, 54 FR 34327, Aug. 18, 1989]
Old August 10th 04, 03:09 PM
J. Hansen
"steve mew" wrote in message ...
supersonic flight ?
Sec. 91.817 - Civil aircraft sonic boom.
true flight Mach number greater than 1 except in compliance with
conditions and limitations in an authorization to exceed Mach 1 issued
to the operator under appendix B of this part.
from an airport in the United States, unless --
limitations that ensure that flights entering or leaving the United
States will not cause a sonic boom to reach the surface within the
United States; and
limitations in an authorization to exceed Mach 1 issued under appendix
B of this part.
Sec. 91.819 - Civil supersonic airplanes that do not comply with part
36.
that have not been shown to comply with the Stage 2 noise limits of
part 36 in effect on October 13, 1977, using applicable trade-off
provisions, and that are operated in the United States, after July 31,
1978.
person who operates a civil supersonic airplane to or from an airport
in the United States:
under part 21 of this chapter, no person may land or take off an
airplane covered by this section for which the type design is changed,
after July 31, 1978, in a manner constituting an "acoustical change"
under §21.93 unless the acoustical change requirements of part 36 are
complied with.
landing after 10 p.m. and before 7 a.m. local time.
Sec. 91.821 - Civil supersonic airplanes: Noise limits.
1980, no person may operate in the United States, a civil supersonic
airplane that does not comply with Stage 2 noise limits of part 36 in
effect on October 13, 1977, using applicable trade-off provisions.
Appendix B to Part 91 - Authorizations to Exceed Mach 1 (§91.817)
form and manner prescribed by the Administrator and must comply with
this appendix.
1 covered by section 2(a) of this appendix must contain all
information requested by the Administrator necessary to assist him in
determining whether the designation of a particular test area or
issuance of a particular authorization is a "major Federal action
significantly affecting the quality of the human environment" within
the meaning of the National Environmental Policy Act of 1969 (42
U.S.C. 4321 et seq.), and to assist him in complying with that act and
with related Executive Orders, guidelines, and orders prior to such
action.
1 covered by section 2(a) of this appendix must contain --
is necessary to accomplish one or more of the purposes specified in
section 2(a) of this appendix, including a showing that the purpose of
the test cannot be safely or properly accomplished by overocean
testing;
including an environmental analysis of that area meeting the
requirements of paragraph (b) of this section; and
sonic boom overpressure will reach the surface outside of the
designated test area.
action is necessary to protect or enhance the environment.
Section 2. Issuance
Mach 1 may be issued when the Administrator has taken the
environmental protective actions specified in section 1(b) of this
appendix and the applicant shows one or more of the following:
requirements.
characteristics of the airplane or to establish means of reducing or
eliminating the effects of sonic boom.
limitations under which speeds greater than a true flight Mach number
of 1 will not cause a measurable sonic boom overpressure to reach the
surface.
to exceed Mach 1 may be issued if the applicant shows conservatively
under paragraph (a)(3) of this section that --
reach the surface when the aircraft is operated under conditions and
limitations demonstrated under paragraph (a)(3) of this section; and
operating conditions.
Section 3. Duration
is surrendered, or until it is suspended or terminated by the
Administrator. Such an authorization may be amended or suspended by
the Administrator at any time if the Administrator finds that such
action is necessary to protect the environment. Within 30 days of
notification of amendnent, the holder of the authorization must
request reconsideration or the amendnent becomes final. Within 30 days
of notification of suspension, the holder of the authorization must
request reconsideration or the authorization is automatically
terminated. If reconsideration is requested within the 30-day period,
the Administrator may terminate or amend the authorization if the
Administrator finds that such action is necessary to protect the
environment, or he may reinstate the authorization without amendment
if he finds that termination or amendnent is not necessary to protect
the environment.
not affect any certificate issued under title VI of the Federal
Aviation Act of 1958.
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 4th 03 12:53 AM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 08:43 AM
