Verifying flap retraction
Old August 17th 04, 05:26 PM
Dudley Henriques
Most of the problems that I have had on Cessna 172s have been with
flaps. I
agree that pilots should verify flaps up on touch and goes.
Cessna used to have manual flaps. Why did they ever go to this flakey
electrical system in the first place?
The old "Johnson bar" could be fun. You had to depress the button in
front by lifting the pressure gently off the bar. Every now and then if
you weren't careful, the damn thing could slip out of your fingers and
slam down, retracting the flaps in one hell of a hurry.
You could always tell the CFI's who had had this happen to them when a
student let the bar go on a low altitude go around. They would be the
ones with the snow white hair!!! :-)
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please
replace the at with what goes there and
take out the Z's please!
dhenriquesZatZearthZlinkZdotZnet
Old August 18th 04, 03:00 AM
Roger Halstead
On Tue, 17 Aug 2004 15:26:45 GMT, "Dudley Henriques"
flaps. I
The old Hershey Bar winged Cherokee 180s also used the Johnson bar.
It was the only plane where I could raise the flaps and actually
shorten the landing roll. The electric ones are just too slow.
In nearly 375 hours I never dropped the bar once.
Man, when doing a short filed landing you put the bar full forward as
soon as the mains were down. It felt like the gear got a foot shorter
when that bar went forward. :-))
G-III almost done except for the last 90%
www.rogerhalstead.com
Dudley Henriques
Old August 18th 04, 02:07 PM
Cub Driver
On Wed, 18 Aug 2004 01:00:01 GMT, Roger Halstead
I took Damien Del -- well, I took the Andover NJ "bush flying" course
last year. He taught this technique in the Aviat Husky. (Also flying
in ground effect over the corn stubble short of the threshold, then
dumping the flaps just as you reach the grass. Voila! 250-foot
landing!)
I had a bleeding knuckle after a couple hours of this.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
Expedition sailboat charters www.expeditionsail.com
Old August 19th 04, 02:04 AM
Roger Halstead
On Wed, 18 Aug 2004 08:07:16 -0400, Cub Driver
landing!)
Couple years ago I took part in a spot landing contest. It was pretty
much a no rules type rather than you and only reduce throttle and add
flaps type of thing.
I thought I was doing pretty good touching down on the mains with
something like 21 or 22 inches to go. The a couple pilots flying a 172
both made 11 inches. Then the FBO, Terry Blodgett got out his old
V-35. He set the mains on the tape and cut it in two.
At any rate, where I was headed was Cherokees, Johnson bars, and short
fields. There was a Cherokee that came in with all seats full. I
think it was a Cherokee 6, but it's been a while. At any rate (think I
already said that), he was dragging it in and then dumped the flaps.
Thing is, he was a tad higher than he though. It sounded like someone
dropped a trash can on the runway. A big trash can:-)) All that and
he didn't come close to the 4 closest landings.
Those Cherokees are rugged! I've seen proofsnicker
Just one?
The Warbird's Forum
Old August 17th 04, 05:44 PM
Richard Russell
On Tue, 17 Aug 2004 07:56:53 -0700, "C J Campbell"
Most of the problems that I have had on Cessna 172s have been with flaps. I
Recently, I've been flying a 1956 C172 and I like the manual flaps. I
don't miss the convenience of electric flaps at all. Plus, if the
feeble old electic system craps out I still have flap. I know you can
land without them, but my home base is a relatively short runway with
trees on each end.
Rich Russell
Old August 18th 04, 08:08 AM
bangbang
Hey, that was the primary reason why I bought a 1965 airplane - manual
flaps. Love 'em...
In article , C J Campbell
David Herman
N6170T 1965 Cessna 150E
Boeing Field (BFI), Seattle, WA
Visit the Pacific Northwest Flying Forum -
http://www.smartgroups.com/groups/pnwflying
Old August 17th 04, 05:04 PM
Roy Smith
I did my initial training in Cessnas, and "verify flaps retracting" was
drummed into me as part of the touch-and-go procedure.
Now I fly mostly Pipers. I really like the manual flaps instead of
Cessna's electric ones, and curse the electric trim Piper uses instead
of Cessna's manual trim system.
Simple stuff just works better.
Old August 19th 04, 04:44 AM
G.R. Patterson III
Maule gives you manual systems for both!
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old August 19th 04, 04:00 PM
Paul Sengupta
"Roy Smith" wrote in message
Is there not a manual trim wheel then?
Paul
Old August 19th 04, 04:42 PM
Roy Smith
Paul
There is, but it's not in a very convenient place (stuffed between the
front seats). The Piper electric trim is very convenient when it works,
the problem is that it so often doesn't work :-(
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 11:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 07:01 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 01:09 AM
McFarlane flap rollers - PIREP please Roger Long Owning 3 November 3rd 03 11:04 PM
Flap design question Chris W Home Built 1 August 4th 03 03:50 PM
