Flap angles
Old May 15th 04, 09:51 PM
DeltaDeltaDelta
Default Flap angles
I was leafing through the C172N POH for some flap settings yesterday and a
thought occured to me: there was a post here about some verions of the 172
having different full flap angles - some have 40 and 38 degrees. So i
wonder, how do they determine these angles for all flap settings when the
plane's still on the drawing board? Or is it an airfoil design thing? I've
noted that for example the Learjet 45 has first setting at 8 degrees. How do
they determine what is the right angle for each setting?
Triple Delta
Old May 15th 04, 11:46 PM
HECTOP
"DeltaDeltaDelta" wrote in message
If you read Russian (who knows, you might , check out this paper:
http://www.sla.ru/aviamaster/zipfiles/mexan_wing.pdf
it pretty much answers all your questions and more.
HECTOP
PP-ASEL-IA
http://www.maxho.com
maxho_at_maxho.com
Old May 16th 04, 02:48 AM
Blanche
Another option is to look for an aerodynamics course at a college
near you.
Old May 16th 04, 03:32 AM
Bob Martin
"John T Lowry" wrote in message link.net...
They don't write the POH (AFM) until they've performance tested the
prototypes.
I think he's asking why manufacturers designate the flap settings as
they do (not which setting should be used when). For example, the
G550 has flap settings of 0, 10, 20, and 39; his question is something
like "why 39 and not 40?" or "why do some 172's have 40 degrees of
flap avalible and others only have 38?" Or "why are flap settings not
evenly spaced?" Basically, how do they determine what flap intervals
should be available?
Old May 16th 04, 04:06 AM
Teacherjh
Dunno about 38, but the newer ones have 30, because full 40 degree flaps were
causing problems (which I can't recall) due to poor technique of some sort.
Might have something to do with slips with flaps, IIRC.
Jose
Old May 16th 04, 04:25 AM
HECTOP
"Teacherjh" wrote in message
were
sort.
at 40 deg they sucked for crosswinds and that probably ruined a student or
two complete with cross-control flutter, but were great for "carrier-deck"
landings
HECTOP
PP-ASEL-IA
maxho_at_maxho.com
Old May 16th 04, 01:42 PM
Rick Durden
Jose,
I'm always amazed at the amount of misinformation running around here.
Cessna switched to 30 degrees of flap deflection maximum on a heavier
model of the 172 because of rate of climb requirements during a balked
landing under the FARs. The earlier airplanes could meet the rate of
climb with 40 degrees, the newer ones could not, so flap travel was
limited to 30 degrees.
There is no problem with slips with full flaps on a 172, it's another
of aviation's old wives tales.
For an interesting descent rate, fly a Cessna O-1/L-19 (Model 305)
Bird Dog. It had 60 degrees of flaps available.
All the best,
Rick
Old May 16th 04, 03:45 PM
G.R. Patterson III
That's also the reason the 160hp Maule has only 40 degrees of flaps while more
powerful ones have 44 degrees. Even at that, max gross is 200 pounds less than the
180hp version.
George Patterson
I childproofed my house, but they *still* get in.
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 11:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 07:01 AM
TAS vs. flap reflex angle ELIPPSE Home Built 3 January 13th 05 07:00 AM
Duluth - Blue Angles this weekend Montblack Piloting 18 September 23rd 03 04:00 AM
What should the flap postions be while taking off? Shi Jin Military Aviation 2 September 10th 03 02:22 AM
