Ignition problem?
Old June 26th 04, 11:24 PM
nauga
Default Ignition problem?
My #3 cylinder has always run a little cold
on the right mag only. I fixed what I thought
was an intake leak 20 hours ago and that helped,
or at least seemed like it, but today it became
clear that #3 was not firing at all on the right
mag. To make a very long story a little shorter,
the problem travels with the ignition lead. If I
switch top and bottom leads on #3, it still goes
cold on the right mag, which tells me that it's
not the plug. The harness checks fine on a lead
tester, and when I finally broke down and pulled
the mag I was able to 'spark out' all four leads
against the mag case. I was expecting either the
#3 lead would be bad or it wouldn't spark, but it
looks like that's not the case.
Anybody ever see anything like this? Anyone got
any suggestions?
Note that this is *not* the cylinder I replaced.
On both mags the engine is noticably smoother
than before the new cylinder.
Details:
Lyc O-320D
Slick mags
The mags, harness, and plugs are about 6 months old
Good compression check
Dave '3-2-1-pffffft' Hyde
RV-4 in flight test, EAA tech counselor
Fiberglass Cowl Problem Boelkowj Home Built 6 December 20th 03 03:08 PM
Garmin 195 screen problem BPattonsoa Home Built 30 December 3rd 03 03:14 AM
Hot Spark Ignition Larry Smith Home Built 26 November 19th 03 09:24 PM
Electronic Ignition Andre Home Built 1 September 5th 03 07:15 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 02:37 AM
