circumnavigating Chicago Class B
Old September 17th 04, 07:50 PM
Bob
"Travis Marlatte" wrote:
Most people transition the lakeshore at 2000. Personally, I do it at 2200 or
1800.
Is this option something you'd consider for a Cub or Champ
cruising at 70 mph with a battery operated radio and no
XPDR? If heading from the east coast (Mass) to Oshkosh in
such an old timer how would you go? I doubt I can get over
the top. Around the west side of Chicago or up through
Canada are pretty far at such a slow speed, and 50 miles
over water on the direct route is not something I'm anxious
to try.
Old September 17th 04, 11:08 PM
john smith
In 20+ years of going to OSH from OH, I have only gone over the top
once. All but one other time have been along the lakeshore. The other
exception was around the west side in 1985 in a Champ. That was to stop
for lunch and fuel at Clow.
1800.
to try.
Old September 18th 04, 12:38 AM
Viperdoc
I have flown the low altitude route as well as over the top VFR and much
prefer the high altitude. If you have an engine problem you have a lot more
options, and traffic is a lot more visible up high.
Don't forget that all of the heavy iron has TCAS and will see you on the
screen well before you see them.
Old September 18th 04, 02:56 PM
Travis Marlatte
No radio? No problem. No XPDR? Oops. You'd have to be pretty far out over
Lake Michigan to be outside the ORD class B 30nm mode C veil. So, that
depends on your definition of risk. Do you mind being 15 miles offshore with
no floats and a battery operated radio that might not transmit to shore and
no XPDR so that they could track your splash?
That's too much risk for me. I'd stick to the farm fields south and west of
the class B veil.
Travis
"Bob" wrote in message
or
1800.
to try.
Old September 18th 04, 03:47 PM
Steven P. McNicoll
"Travis Marlatte" wrote in message
ink.net...
with
and
of
the class B veil.
Most Cubs and Champs were built without electrical systems and thus are
exempt from the transponder requirements of the Mode C veil.
Old September 18th 04, 05:11 PM
john smith
Yep! I can fly right up to the inner-most cylinder, below 1200' AGL.
Old September 18th 04, 07:14 PM
G.R. Patterson III
He said a Cub or a Champ; that is, an aircraft that was built with no electrical
system. He can fly such an aircraft within the veil as long as he stays out of the
class-B itself.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old September 18th 04, 11:35 PM
Travis Marlatte
Oops. Sorry. I guess I should have assumed that from the "battery operated
radio" phrase.
Then it's a phone call to get permission, right?
Travis
ink.net...
ink.net...
over
with
and
of
the class B veil.
Old September 18th 04, 11:48 PM
Peter Duniho
ink.net...
radio" phrase.
Only to operate within the Class B itself. Which is not what they are
suggesting.
Old September 18th 04, 11:53 PM
Steven P. McNicoll
ink.net...
radio" phrase.
No. No permission is required for VFR flight in the Mode C veil.
Negative XPDR - under the outer ring of Class C bcjames Piloting 8 August 31st 04 12:49 AM
Run-in with Chicago Center Jay Honeck Piloting 93 August 24th 04 05:53 PM
Overlapping class C & D Andrew Sarangan Piloting 14 May 6th 04 05:08 AM
