Which factory makes/ normalizes 4130 sheet ?
Old July 8th 04, 11:11 AM
Malakka
Default Which factory makes/ normalizes 4130 sheet ?
Old July 9th 04, 07:56 AM
Bruce A. Frank
Malakka wrote: it all in the subject line
Thus, 08 Jul 2004 09:11:54 GMT
Nobody. You can obtain 4130A but not 4130N. Some aircraft manufacturers
are obtaining A and having it heat treated to N. Which from a
metallurgical point is a waste of time and money. 4130N is no longer N
after it is welded, but the parts were certified with N and it is just
easier to treat it themselves.
The last steel company producing N sheet went bankrupt and no one else
has stepped up to the plate to set up production. Some thicknesses are
still available in Normalized condition.
If the completed part is going to be heat treated after fabrication it
makes no difference whether you start with A or N. And there are few
cases where you weld fabricate a part and use it as-welded where it
makes any difference either.
Bruce A. Frank
Aircraft Projects
Fuel Tank Fabrication
TIG, MIG & Oxy/Acet Welding & Brazing
Old July 12th 04, 03:15 PM
FIyer111
Ok..so what are some alternatives to 4130 that we can use on the planes we are
building?
Dave
4130 sheet source Leon McAtee Home Built 7 May 2nd 04 09:29 PM
4130 Chromaloy Sheet Availability c hinds Home Built 1 January 24th 04 05:17 AM
