Garmin 430 VOR reception
Old September 29th 04, 03:26 PM
Maik
Default Garmin 430 VOR reception
Hi!
I have a SL30 and a GNS 430 in my plane. They use the same antenna via a
splitter.
When I dial in the same VOR in both units the SL30 catches up the
radials always between 20 and 50 nautical miles earlier than the GNS
430! (Altitude about 3000 ft, flat area)
Is this normal?
What is your experience?
How far away do you have a reception of a VOR with your GNS 430?
Fly safe!
Maik
Old September 29th 04, 03:49 PM
Rich
I can't speak for the GNS 430, but the SL30 has UNBELIEVEABLE signal
processing capability. I can track a good VOR well over 100 miles, and
I've got a mediocre cats whisker antenna mounted on my tail. I'm told
the SL30 uses digital signal processing; I don't know what the GNS 430 uses.
In short, I'm not at all surprised by your experience.
Rich
Maik wrote:
Hi!
splitter.
Is this normal?
Fly safe!
Maik
Old September 29th 04, 05:56 PM
john smith
It would seem that UPS-AT technology is significantly better than Garmin's.
Rich
Maik wrote:
Hi!
a splitter.
Is this normal?
Fly safe!
Maik
Old September 29th 04, 06:14 PM
uses.
VOR reception range is dominantly determined by line-of-sight. However, in
marginal situations (i.e. the station is just over the horizon) receiver
quality and/or antenna cable loss can make a significant difference. I do
not know if he VOR processing system in the GNS 430 is similar to the one
used in the SL30, however a simpler explanation for the difference could be
different RF losses in the cables from the splitter to the receiver. By the
way, a VOR test system could quantify the sensitivity difference very
quickly with a simple over-the-air test.
-Elliott Drucker
Old September 29th 04, 10:30 PM
Dean Wilkinson
The VOR signal out of the receiver is a 9960Hz sine wave that is AM
modulated at 30Hz and FM modulated at 30Hz. The phase difference
between the AM and FM signals is the bearing to the station.
Outside of the standard service volume of a VOR, this signal starts to
get quite noisy. This makes domodulating the AM and FM components
more difficult as the signal to noise ratio degrades. The quality of
the filtering of the 30Hz and 9960Hz bandpass filters (or equivalent
digital bandpass filters in a DSP) determines how far out you can
accurately receive the station. Apparently the SL30 does a better job
of filtering out the noise than the GNS430.
Dean
Maik wrote in message ...
Hi!
splitter.
Is this normal?
Fly safe!
Maik
Old September 30th 04, 12:33 AM
Teacherjh
How does that work. =Something= has to be directional, no?
Jose
(for Email, make the obvious changes in my address)
Old September 30th 04, 03:18 AM
Ron Natalie
"Teacherjh" wrote in message ...
Yes, one of the two signals is swept directionally either by electronic or
mechanical means (it doesn't matter which one as long as they are moving
in the right direction relative to the other).
Old September 30th 04, 04:48 AM
DP
I wouldn't be satisfied with the answer that one unit is more sensitive or
has better demod until I knew that the splitter, connectors, and coax were
all in good shape. Then I'd wonder if the Garmin was detuned somehow instead
of jumping right on poor or lesser design.
Dan
Old September 30th 04, 05:26 AM
Dean Wilkinson
Jose,
The FM component goes out the same in all directions from the VOR
station. The AM component varies with the angle from the station.
North of the station there is no phase difference. At 45 degrees the
AM component lags the FM component by 45 degrees, and so on. The AM
component is phase shifted by a phased-array of antennas around the
VOR station.
Dean
(Teacherjh) wrote in message ...
Jose
Old September 30th 04, 05:54 AM
Jim Weir
Not quite.
There is a subcarrier modulation on the main carrier that is 9960 Hz. amplitude
modulated onto the main carrier. The subcarrier is FM modulated with a 30 Hz.
reference signal. The subcarrier is transmitted equally in all directions.
The carrier is also transmitted by a series of antennas spaced around the
station. These antennas are fed by a mechanism rotating at 30 Hz. and
phaselocked to the subcarrier reference. The rotating antenna is calibrated so
that the rotating signal and the reference signal are perfectly in phase at due
north of the station. As you rotate around the station, the phase between the
rotated (variable) and constant (reference) signal changes degree of phase for
degree of rotation.
(There is another way of doing it, far more technically difficult to explain.)
(Teacherjh)
-The VOR signal out of the receiver is a 9960Hz sine wave that is AM
-modulated at 30Hz and FM modulated at 30Hz. The phase difference
-between the AM and FM signals is the bearing to the station.
-How does that work. =Something= has to be directional, no?
-Jose
http://www.rst-engr.com
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 02:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
garmin 296 Robert M. Gary Piloting 1 June 16th 04 07:59 PM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 03:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 10:32 PM
