"Laser injures Delta pilot's eye"
Old September 29th 04, 04:58 PM
Mike
Default "Laser injures Delta pilot's eye"
A pilot flying a Delta Air Lines jet was injured by a laser that
illuminated the cockpit of the aircraft as it approached Salt Lake
City International Airport last week, U.S. officials said.
at http://www.washtimes.com/national/20...1356-3924r.htm
Old September 29th 04, 05:25 PM
Larry Dighera
On 29 Sep 2004 07:58:03 -0700, (Mike) wrote in
at
Welcome to the 21st century where technology enables the irrational to
realize their worst nightmares.
John Mazor, a spokesman for the Air Line Pilots Association, said
commercial pilots have been exposed to laser illumination.
"The Air Line Pilots Association has received reports in the
past of incidents where lasers penetrated cockpits and, in at
least one case, caused injury," Mr. Mazor said.
Several years ago, a pilot flying into a Western airport was
hit by a light from a laser light show. The causes of the other
incidents are not known, he said.
Asked whether a laser aimed at pilots could cause a plane to
crash, Mr. Mazor said: "I think that's highly improbable. In every
case in the past, the flights landed safely."
Military personnel also have suffered eye damage from laser
illumination.
In one case, Naval Lt. Cmdr. Jack Daly and Canadian helicopter
pilot Capt. Pat Barnes suffered eye injuries hours after an aerial
surveillance mission to photograph a Russian merchant ship that
had been shadowing the ballistic-missile submarine USS Ohio in
Washington state's Strait of Juan de Fuca.
The Navy recently turned down an appeal from the Defense
Department inspector general to award Cmdr. Daly a Purple Heart
for the incident. Cmdr. Daly, who retired from the service last
year, continues to suffer eye pain and deteriorating vision.
During congressional testimony in 1999, he warned of laser
threats to pilots.
"Numerous documented cases regarding the use of lasers against
aircraft, civilians and military personnel exist, as well as does
an all-too-lengthy list of the injuries that have resulted from
the accidental and intentional misuse of these devices," Cmdr.
Daly told a House Armed Services subcommittee.
He noted that incidents of lasers being directed at commercial
airliners during takeoff and landings have raised fears that "this
in fact may be a new form of terrorism."
"Lasers are easily obtainable and can be self-manufactured
weapons in the terrorist arsenal, which essentially can effect a
soft-kill solution and leave virtually no detectable evidence," he
said.
Old September 29th 04, 07:18 PM
Andrew Gideon
said.
The "Hunt for Red October" author used something similar in one of his
books. A spy used such a technique to bring down enemy aircraft by
"flashing" them while on short final.
He also used the idea of airliners flown into buildings well before 2001.
- Andrew
Old September 29th 04, 07:58 PM
AES/newspost
at
illumination.
In the vast majority of these cases, "dazzled", and ergo potentially
"endangered" would be valid terms, "injured" would not.
The primary hazard to pilots from laser radiation at the distances and
with the most commonly used types of lasers in the light-show and even
in the military scenarios is going to be the kinds of instantaneous and
short-term visual impairments that would be associated with the term
"dazzling" -- that is, loss of night vision, temporary loss of all
vision of the sort resulting from looking at any bright light source,
possible severe disorientation if the pilot keeps trying to look at
instruments or outside the aircraft while this dazzling continues --
rather than permanent eye damage or injury. Temporary deterioration
of vision caused by such dazzling effects is obviously a very serious
matter; but it would require quite unusual optical beam power levels to
produce permanent eye damage or injury from a laser beam in aviation
situations.
My understanding is that deliberate dazzling of enemy pilots has in fact
been used in various military situations in recent years, but public
information concerning this is limited.
I do have some familiarity with the Daly case. Both a prolonged,
detailed and extensive investigation by the U.S. Navy and also the jury
verdict in a subsequent civil damages trial concluded that it was very
unlikely Daly was even illuminated by a laser beam during the mission
referred to, much less injured by it. There are also other quite
questionable assertions even in the one paragraph quoted above.
Old September 29th 04, 08:33 PM
Ron Natalie
Airplanes have flown into buildings well before 2001.
Old September 29th 04, 09:00 PM
Jay Masino
Plus, the whole idea of taking down an airliner with this method is flawed
because you'd really have to take out both pilots.
--- Jay
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old September 29th 04, 09:24 PM
Casey Wilson
"Mike" wrote in message
om...
I read the article. In a former life, I worked in a laser laboratory
with high-powered lasers capable of inducing significant damage. Laser
damage, when it occurs, is instantaneous and irreversible. That's part one.
Part two, divergence and scattering through the atmosphere will
significantly reduce the energy per unit area. At any range over a few
thousand feet you'd need a weapons grade laser to produce anything more than
the so-called dazzle effect.
Part three, the dazzle effect can be dangerous if it affects a person's
ability to perform a required task -- whether it is a pilot or a tank
driver.
Part four, weapons grade lasers don't operate in the visible spectrum
(mostly) and don't cause dazzles. (Why? Because if you operate a laser in
the visible spectrum on a battlefield someone is going to shoot at you.)
Part five, lasers used in light shows don't have the energy required to
cause tissue damage outside a few meters range.
For the moment, I'm skeptical of the damage to the Delta pilot's eyes.
Oh, I almost forgot, I was involved in an incident where a person got
flashed with a laser. The investigation lasted more than three months. The
end result was "Mr. (blank)'s left eye was not damaged by the (blank)
laser." The report went on to say the symptoms were psychosomatic.
Old September 30th 04, 04:01 AM
Richard Hertz
"Jay Masino" wrote in message
2001.
--- Jay
From what I recall it wasn't a laser, rather an extremely bright light aimed
at the cockpit during a landing or takeoff and incapacitated both pilots so
that the plane hit the ground hard.
Clancy is a fiction writer.
He's not the first to make stuff up.
__!__
Old September 30th 04, 08:13 AM
Montblack
("Jay Masino" wrote)
Flawed?
It's child's play. You wait in the weeds with your ..."laser" until the first
pilot has an aneurysm, then you zap the second pilot with the ..."laser."
Where's that surplus Agent Orange? TSA needs to get rid of terrorist-friendly
ground cover. Never mind, they're already spraying, late at night.
Montblack
"My dear fellow! This isn't Spain ... this is England!"
A Man For All Seasons (1966)
Winner of six Academy Awards - including Best Picture
Old September 30th 04, 12:35 PM
CV
Subtle shift in meaning there.
There was no widespread public awareness of the idea of them
_being_ flown into buildings before then.
CV
Dover short pilots since vaccine order Roman Bystrianyk Naval Aviation 0 December 29th 04 01:47 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 05:24 AM
[OT] USA - TSA Obstructing Armed Pilots? No Spam! General Aviation 3 December 23rd 03 09:53 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
