Pilot deviations and a new FAA reality
Old October 11th 04, 01:07 AM
TJ Girl
Larry Dighera wrote in message . ..
That FAAO mentions: "The identification of operational errors and
deviations without fear of reprisal is an absolute requirement and is
the responsibility of all of us who work within our [NAS] system."
Careful of pulling this from context. The word "operational" above
applies to both "errors" and "deviations".
An operational deviation is NOT the equivilent of a pilot deviation.
An operational deviation would be something like a controller letting
a pilot enter another controller's airspace without a handoff or other
form of coordination.
Operational deviations are what are required to be reported under that
section, not pilot deviations.
  #74
Old October 11th 04, 02:16 AM
Matt Young
WAFDOF?
Stan Prevost wrote:
"Chip Jones" wrote in message
link.net...
OK pilots, try this one on for size. As you likely know, there is a wide
and growing rift between the career FAA bureaucrats (aka FAA Management)
who
run the monstrosity called the federal Air Traffic Organization, and the
career FAA air traffic controllers who make that monstrosity work in the
NAS
on a daily basis. Regardless of where you stand on the politics of US air
traffic control (funding, privatization, user-fees, labor issues,
whatever),
the ugly, on-going feud between Management and Labor in air traffic
control
may finally have reached a point where you as a pilot will be personally
affected.
Chip, increased emphasis on reporting of pilot deviations seems to lead to a
need for increased pilot understanding of what constitutes a deviation from
an ATC point of view. I doubt that controllers are required to know the
FARs to the depth required to determine if a pilot is operating within the
regulations that apply to pilots in all cases, so a large part of it would
seem to fall back on reporting deviations from an ATC instruction or
clearance. So what constitutes a deviation? As an example, what deviation
in altitude constitutes a reportable deviation, if no loss of separation
occurs? It has been suggested in this thread that the Instrument PTS
standard of +/- 100 ft applies, but I doubt if controllers are familiar with
the PTS. So is there an ATC document that defines deviation limits? How
far off the centerline of an airway can I be before being reported? How
much heading error? How long a delay is allowed before I begin a descent
after being instructed to do so? If I am VFR in Class E airspace, and using
flight following, will I be reported for flying WAFDOF? Should we expect a
report on every student pilot doing T&Gs and landing without clearance,
rather than being scolded for a one-time error, if no problem occured?
Looks like a big can of worms to me.
Sta
  #75
Matt Young
WAFDOF?
link.net...
who
NAS
whatever),
control
affected.
Sta
  #76
Old October 11th 04, 03:03 AM
Roy Smith
In article . net,
Matt Young wrote:
WAFDOF?
Wrong Altitude For Direction Of Flight, flying westbound at 7500 instead
of 6500.
  #77
Roy Smith
In article . net,
Matt Young wrote:
WAFDOF?
of 6500.
  #78
Chip Jones
"Stan Prevost" wrote in message
a
from
deviation
with
We give you 200 feet, plus the change if I remember correctly. When you get
to 300 feet above or below assigned altitude, your data block "breaks" and
ATC considers that you've busted your altitude.
How
4 miles...
How
much heading error?
Good question. As a Center guy, I don't have a ready answer. To me, it
depends on whether you are assigned a heading/vector for traffic or if you
are navigating airways or point to point own nav. If you're on an assigned
vector, say 30 degrees left for traffic, and I never see you make the turn,
to me you have deviated your clearance. However, for FSDO you will likely
never get stuck with a PD, because I can't prove where the winds are etc.
Too many variables in all of these categories for me.
US Airways, Delta and Northwest have all been guilty in my ARTCC of reading
back descent clearances and then remaining at the original altitude for over
five minutes before staring a descent. To the controllers involved who
subsequently were charged with operational errors when USA, DAL and NWA lost
vertical separation with traffic, the crews were guilty of PD's for not
adhering to clearance. In all three cases, FSDO refused to prosecute PD's,
even though the AIM (non-regulatory) was not complied with by the pilots who
read back those clearances. Sadky, I have no idea how long a delay is
allowed, and neither does anyone else in the system. I know what I think
constitutes as PD here, but I'm biased towards you starting a descent as
soon as you acknowledge the clearance. FSDO doesn't agree with me in this
area of the country.
Well, according to the ATC QA Order you should be reported if you are
violating any FAR's.
Should we expect
a
Really productive for air safety, ain't it?
It's all a huge can of worms better left unopened, IMO.
Chip, ZTL
  #79
Chip Jones
a
from
deviation
with
How
4 miles...
How
much heading error?
Should we expect
a
Chip, ZTL
  #80
Old October 11th 04, 03:24 AM
J Haggerty
C Kingsbury wrote:
"Larry Dighera" wrote in message
On Sat, 09 Oct 2004 18:39:39 GMT, "C Kingsbury"
wrote in
nk.net::
In most states you can get ticketed for "failure to stop at a stop sign"
for
something as simple as not coming to a complete stop. You slow to less
than
Actually, there is a rational reason for making a complete stop at a
boulevard stop sign.
There is no rational reason when you can clearly see there is no conflicting
traffic within a mile, unless you count the slippery-slope theory, and I
don't.
Yeah, the guy that ran into my bike with his van as I went through the
intersection thought he slowed enough to see all traffic, too. If he had
stopped completely, he would have seen me. Unfortunately, he rolled
through, and did not see me because I was hidden from his sight by his
"A" pillar, which was keeping me hidden from his view (in his blind
spot) because he kept moving through the stop sign. This is one good
reason why you should come to a stop at a stop sign. Of course the few
seconds he might have saved ended up being an expensive proposition for
him, and a painful visit to the hospital for me.
Now, perhaps when management gets deluged with
reports of 50' altitude deviations and other trivial mistakes,
Because mode c transponders only report altitude in even hundreds,
that isn't very likely.
OK, 51' then. You get my point. There are deviations that clearly require
reporting and others that can be pretty effectively addressed by an ATC
tonguelashing. Unless someone shows me evidence that safety is being
degraded by failure to report every possible PD I'm going to say that the
way things work today are fine.
Actually, as a controller, I never considered or questioned an enroute
altitude deviation unless it exceeded 300' or was a threat to another
aircraft. At that point a controller has to determine if the pilots mode
C is incorrect or if he has just deviated from the assigned altitude.
The increased workload may be sufficient to stimulate demand for
additional ATC personnel hiring.
No, it will stimulate demand for more desk-bound paper-pushing "inspectors"
whose biggest concern is a loss of separation between them and their lunch
break. No government bureaucracy has ever responded to added workload by
becoming more efficient.
Until we
know the language of the regulations governing ATC reporting PDs, it
is difficult to form an opinion as to the appropriateness of the
change in policy.
Well, I wouldn't say so. There is a perfectly good argument to (a) have a
regulation that requires reporting every PD and (b) routinely ignore it.
Basically, you need to have the rule, so that you can go after a controller
who reports nobody no matter what because he's lazy. OTOH, reporting every
single incident when not necessary in the controller's view is just
paper-chasing and serves no end.
I will abort this line of argument if someone can show me that there is a
real safety issue here backed by something more than a gut instinct.
The example Chip gave was something that should have been reported
without a second thought. The example included another pilot having to
take evasive action because an aircraft entered the runway without
approval. Whether the pilot initiated the go-around or it was directed
by ATC is irrelevant, plus runway incursions are a hot topic in the FAA
these days, generating their own special reporting.
JPH
-cwk.
Pilot deviations and a new FAA reality Chip Jones Instrument Flight Rules 36 October 14th 04 07:10 PM
Moving violation..NASA form? Nasir Piloting 47 November 5th 03 08:56 PM
