#11
On Sun, 21 Nov 2004 23:51:25 GMT, Mitty wrote:
I've been taught to set the prop to high RPM on final, but I don't like this very much because then, when I run my checklist for the first time on downwind, I have to leave one item "open." So what's wrong with doing it on downwind? (This in a Cherokee 6 or and Arrow) It seems to work fine, does not disarrange the engine, etc. I suppose there is some small noise increase, but hardly much. So (1) is everyone taught to do it on final? (2) Why? (3) What's wrong with doing it on downwind? TIA Full forward (high RPM) is in case of a go around. Going high pitch mid-field will create a really loud racket on the ground. Waiting until short final is too late in my opinion since we're human and can forget things. To avoid this I go full forward (high RPM) when I make my initial power reduction (generally abeam the numbers). This causes no noise increase, and time for me to double check as I fly the pattern. Hope this helps. z |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
