#11
"Chris" wrote in message
... [...] With the 182, it is 80 knots turning from the 45 to downwind, 75 on base, and 70 on final. I don't understand why pushing the prop to full flat has any noise effect whatsoever. Exactly Exactly, except for those airplanes that cannot maintain level flight at pattern speed with gear and flaps out at final descent power settings. Which is, by the way, all airplanes with a constant speed prop. The power setting for final descent is necessarily lower than that required for level flight within the pattern, even if you slowed ALL the way to your final approach speed. RPM will thus be higher, assuming the pitch is set to full fine pitch (high RPM). Higher RPM means more noise. If Jim's 182 flies along level in the pattern at the same airspeed and prop RPM that he uses for final descent, I have no idea how he accomplishes a final descent at all. A plane like that would be stuck up in the pattern indefinitely. Pete |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
