Your fancy schmancy dream machine
Old July 26th 03, 08:44 AM
Jerry Springer
Jay wrote:
Hey I resemble that remark. By now many of you may have viewed my
fancy dream machine at:
http://inline_twin.tripod.com/concept.html
And you're pointing out something I've seen a few times here in RAH
and maybe we need a rec.aviation.experimental
Some people want to push the boundaries, even if its only in their own
heads, and try to do something new or better than before. And other
people are happy building what someone else designed, and thats great.
It takes all kinds. There's enough drilling, clecoeing, sanding,
layingup, painting to keep anyone busy, but hopefully you don't spend
so much time on the grunt work that you miss the opportunity to
invent.
Jay I took a look at your design concept and your web page. It is a fantastic
concept but I would really hate to be in it flying somewhere always looking at
where I had been instead of where I was going.
I took the liberty to copy a couple some things here for the sake of discussion
that you say on your web page which I take exception with and almost find
offensive to those of us that take pride in the aircraft we built and fly.
and economics has a direct effect on public saftey bacause:
* Expensive up-keep is more likely to be put off.
* Engine replacement will be put off long past when it should be.
* Used engines and components (no joke) will be used and reused in active
aircraft.
* More likely that a broken or worn part will try to be repaired instead of
replaced as it should be.
* Airframe manufacturers are more likely to underpower their aircraft to
reduce cost of goods sold, and increase the proportion of the aircraft that they
build.
I find fault in just about everything you say in the above sentences, I do not
believe that any of it is true and to try to sell a concept on the above
statements is wrong IMO. I post this here because I would like you to submit any
proof you have that the above is true. don't get me wrong I wish you all the
luck in the world with your design but lets keep it real.
Jerry
