Orval Fairbairn wrote:
: When you use autogas, you have to pay close attention to fuel system : design, to avoid sharp corners in lines, cooling paths to gascolators : and even locating boost pumps on the cabin side of the firewall, to keep : things cool. If possible, it would be great to have the return system of an automobile. Flush most of the fuel to the engine and back to the tank. It requires double the fuel lines (and thus double the potential for leakage, etc). It turns the fuel tanks into a huge coldsink to keep the fuel cool as it circulates through the engine compartment. Of course, it's a little different since airplanes operate at a large percentage of their maximum fuel burn. A car typically runs at 10-25% of its maximum power, even on the freeway so fuel burn is 2-3 gph. In a high-perf engine cruising on 14 gph (max probably 20-25 gph), circulating the fuel would require faster pumps... say 2x-3x, or about 1 gpm. Pretty beefy, now that I think about it. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering Ph.D. Graduate Student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| Thread Tools | |
| Display Modes | |
| Hi Octane Autogas | UltraJohn | Home Built | 24 | April 18th 04 03:43 AM |
