HURRICANE PROOF BUILDINGS
Old August 18th 04, 12:31 AM
Matt Whiting
ChuckSlusarczyk wrote:
In article , RobertR237 says...
You are wasting your time trying to reason with Jaun, he is a self proclaimed
expert in all things and nothing will ever change his mind.
Boy you got that right ,it didn't take jaun long to start ragging on people
over material for a building. I guess a cement BD-5 will fly as good as his
perpetual BD-5 project LOL!!
Flame shorts on !!
See ya
Chuck (the guy that designed wood is a pretty good designer) S
Yes, wood is the original composite material.
Matt
  #32
Old August 18th 04, 12:34 AM
Matt Whiting
geo wrote:
"Vaughn" wrote in message
Wood is an amazing building material. A properly designed wooden
structure
will stand up to a hurricane just as well as a properly designed concrete
structure.
I'm not talking about cinder blocks. Reinforced concrete is by FAR the
strongest building material generally available and in the shape of a dome
it's much stronger still. Given the same forces a stick home will be a pile
of splinters while the dome is unscathed. The numbers have been done; it's
not a mystery. http://www.monolithic.com/plan_desig...ive/index.html
Define strongest? Tensile strength? Compressive strength? Stiffness?
Matt
  #33
Old August 18th 04, 12:53 AM
DBlumel
The concrete homes are cooler also...
Until they get warmed up and then they stay hotter.
Its called thermal mass.
  #34
Old August 18th 04, 01:28 AM
Matt Whiting
Yes, and it works both ways. Keeps cool longer once cooled, but also
keeps hot longer once heated.
Matt
  #35
Old August 18th 04, 02:01 PM
Corky Scott
On Mon, 16 Aug 2004 17:01:18 -0400, Matt Whiting
No, concrete designed to withstand hurricans beats wood that wasn't so
designed. The old wood sailing ships took a lot more beating on a daily
basis than is dished out by a hurricane. And they held up rather well.
It is a matter of what loads the structure is designed for, not the
materials used in the construction.
Matt
Matt, this sounds a like hyperbole. "Old wood sailing ships took a
lot more beating on a daily basis than is dished out by a hurricane"?
Really? Catagory 1 storms begin at 74 miles per hour. Have you ever
been in deepwater in a wooden sailing ship when it was blowing at only
74 mph? Because that's the lowest windspeed of the least violent
classification of hurricane.
I've been on a fiberglass sloop on a large lake when it was blowing
steady at 30 knots and gusting to 50 knots. I don't ever want to do
that again, and I for SURE would not want to be out at sea in a wooden
sailing vessel while a category anything hurricane was blowing.
Those old wooden ships demasted on a regular basis and the sea bottom
is littered with their wrecks.
Corky Scott
  #36
Old August 18th 04, 05:50 PM
geo
And I am not talking about reinforced concrete dome houses. I am
talking
about the real-life code-compliant housing that fills up neighborhoods
here in
south Florida. In fact, my post above was not even in response to you,
and
certainly not to some weird structure that lives in your imagination or on
a on
a web page somewhere.
You don't know what you're talking about. Those weird structures have been
built for the last 25 years throughout the world as homes, gyms,
auditoriums, churches, bunkers, storage silos, airplane hangers. They can
and have withstood most natural disasters including hurricanes, fire,
earthquakes and tornadoes. And they're 50%-70% more energy efficient. Given
similar costs why anyone would choose to build a flimsy stick and tar
stylish deathtrap is beyond me.
Last time I checked; here in south Florida, a code-compliant wooden
house
will get the same insurance rate for storm coverage as a comparable
concrete
home. Proper storm shutters and/or Dade approved window and door systems
are a
major item and insurance companies may someday force 100% retrofit in
storm
counties. After window protection, the next most important item for storm
resistance is roof design, not the building material of the walls.
Ten years ago, I toured hurricane Andrew's devastation and saw many
failed
structures, wood, concrete block, and yes; even reinforced concrete.
And I'm sure many of them were code-compliant. That's a false sense of
security. When a cat-5 hits a code compliant house it'll be in splinters.
Code-compliant doesn't mean that's the best that's possible it represents
somebody's idea of what can reasonably be done for the least cost given
commonly used building techniques without upsetting too many people while
making contractors happy.
All those planes (not to mention people) that were damaged or destroyed
would have been untouched in a monolithic dome. It's that simple.
Vaughn (a guy who lives in a concrete house)
What kind of concrete house?
  #37
Old August 18th 04, 08:44 PM
DBlumel
I guess people who live in concrete houses can throw stones.
  #38
Old August 18th 04, 09:09 PM
Matt Whiting
Matt
I was talking about the hull hitting the ways. Hitting a wave at 15-20
knots is a LOT of force. I'd have to do some research to find the
equivalent wind speed to provide the same force as hitting water at 20
knots, but it would be a lot of wind given the density difference
between wind and water.
Again, I was talking hull, not masts, sails, etc.
Matt
  #39
Old August 18th 04, 11:41 PM
Vaughn
"geo" wrote in message news:VUKUc.46144$US4.22088@trndny01...
talking
here in
and
a on
I know exactly what I am talking about and I think I made myself quite
clear. Apparently my reality does not match your reality, so this will serve as
a friendly end our conversation. You may now withdraw to your dome-shaped
hanger with my complements.
Regards,
Vaughn
  #40
Old August 19th 04, 03:29 AM
Matt Whiting
so designed. The old wood sailing ships took a lot more beating on a
daily basis than is dished out by a hurricane. And they held up
rather well. It is a matter of what loads the structure is designed
for, not the materials used in the construction.
Matt
I meant to type waves, not ways!
Matt
Hurricane Charlie and Lakeland Orval Fairbairn Home Built 12 August 17th 04 03:42 PM
