What is a "Forward Skip"?
Old January 6th 05, 08:57 PM
Happy Dog
"569" wrote in message news:
The Cessna 172R has a placard, "Avoid Slips with Flaps Extended". Now
it says, "avoid". It does not say that you can't do it. There was a
discussion in Flight Training Mag about 6 months ago that talked about
that same thing. In the Cessna 152 I always have full flaps in a slip.
I don;t truely understand why having flaps is a problem in the 172R.
The aircraft tends to oscillate on the pitch axis. It's never been shown to
be a hazard though. Just feels a bit weird.
le m
Old January 6th 05, 09:00 PM
Happy Dog
"kontiki" wrote in message
With full flaps its easy to end up real slow in a slip and approach a
stall.
It's easy without flaps too. Stalling isn't the real danger though, it's
spinning. With proper elevator input though, there's no danger of either.
And, this has nothing to do with Cessna's warning.
moo
In the context it is used, and for my level of flying experience, yes
they
are interchangeable. I do not know more about the danger of this than
Cessna, so I would prefer to trust what they say. You level of
experience
is certainly different that mine, so your decision may be different than
mine.
That is not say that in the event of emergency I would not perform a slip
to land with full flaps if the need dictated.
Peter R. wrote:
) wrote:
Cessna 172M
"Avoid slips with full flap extension"
Are the words "avoid" and "prohibited" interchangeable?
Old January 6th 05, 09:03 PM
kontiki
Peter Duniho wrote:
Not with the proper control inputs it's not, nor is that in any way related
to the C172 warning to avoid slips with full flaps.
Well of course. Proper control inputs 100% of the time would eliminate at least
50% of the accidents.
Old January 6th 05, 09:27 PM
kontiki
Spinning requires a stall.
stall.
moo
they
experience
mine.
Peter R. wrote:
) wrote:
Cessna 172M
Old January 6th 05, 09:55 PM
Stefan
it's spinning.
But any properly trained low time student can recover from a stall
without spinning.
Stefan
Old January 6th 05, 10:05 PM
kontiki
I would not necessarily go so far as to say that. Working on my CFI
I had to undergo spin training... actually recovering from spins
multiple times. That training is not nromally a part of student
pilot training.
Remember that a spin requires a stall of one wing... the other
can be flying quite normally. Students are typically tought stalls
under coordinated conditions.
Stefan wrote:
it's spinning.
without spinning.
Stefan
Old January 6th 05, 10:07 PM
Peter Duniho
"AnthonyQ" wrote in message
I was told many years ago that a full rudder slip in a C172 (especially the
older models with 40deg flaps), it is possible to induce a tail stall
You were told wrong.
  #28
Old January 6th 05, 10:08 PM
Peter Duniho
least
The point is that flaps don't change the control inputs required to avoid a
stall in a slip. If anything, they make a stall less likely, since they
lower the stall speed.
  #29
Old January 6th 05, 10:23 PM
kontiki
In theory of course. In the case of the 172 with 40 degrees of flaps they
contribute more drag than lift.
least
  #30
Old January 6th 05, 10:30 PM
kontiki
well, let me be more specific: the last 40 degrees contributes
more overall drag than lift.
eliminate at least
avoid a stall in a slip. If anything, they make a stall less likely,
since they lower the stall speed.
Don't skip that runup! Roger Long Piloting 8 July 8th 04 08:04 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 01:04 AM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 06:50 PM
Honor to those who came forward ArtKramr Military Aviation 51 July 8th 03 12:19 AM
