practical best range application?
Old February 1st 05, 05:28 PM
aluckyguess
"steve.t" wrote in message
If you have a general idea of the best altitude for your aircraft (fuel
economy wise), and you can pull power and lean until you are able to
keep the RPM in the green and maintain altitude, then all you need do
is turn so that the wind is behind you. Remember, the more angle of
attack, the more drag you will have. So you may need to keep more
power, say to 60%. I would guess in my PA28-180 that I would need to
cut power down to about 2000RPM (well above bottom of green). This
would probably put me down in the 4x% range, but with a large angle of
attack. However, if I brought the power up to 2200 and was at ~5000
MSL...
Note that at this point I have not referred to the POH. I'm doing this
sitting here by seat of pants outside the plane.
Without going into lots of physics, I would guess that this would give
you your best time in air and distance.
If you MUST deal with any kind of headwind, then you will have to run
with enough power to overcome the wind. And now you must start doing
some serious figuring as to what altitude gives you your best chance of
getting to where you need to go.
And in the situation you have just given, forget GPS and LORAN. Hope
you have an ADF, because you probably won't pickup VORs either.
Later,
Steve.T
PP ASEL/Instrument
Why would you forget GPS?
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 03:17 AM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 05:20 AM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 03:14 AM
To Steal an F-86 Dudley Henriques Military Aviation 19 August 1st 03 03:26 AM
