Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Surecheck TrafficScope Pirep?
Old September 18th 03, 02:15 PM
BHelman
I did fly with one and had one. The Monroy would give traffic alerts
of almost every airliner flying thousands of feet above me, and others
that passed well below me. It was clear to me very quickly that the
claim of "within 1500 feet" was just not the case. It sounds like you
like that unit, but my opinion is that it was just more of an
annoyance than useful because aircraft well above me or below me (or
even some that never existed at all!) would set it off, where as I
have never had that problem with this traffic scope. I think knowing
the altitude of the other plane is the biggest key. As an example, I
was flying 2 days ago when my traffic scope started showing range
decreasing rapidly and his altitude 200 feet above me, at .6 miles I
STILL did not see him so I just descended 300 feet. about 2 seconds
later the Baron passed above me by 500 feet in exact opposite
direction. With the Monroy I would not have known what to do but
panic. I guess it comes down to personal preference and budget,
because there are still some who do prefer the ADF / VOR as opposed to
upgrading to GPS, in fact I was one for 6 years!!
Thomas Borchert wrote in message ...
BHelman,
The
Monroy doesn't account for altitude, so when you have a 737 flying
overhead thousands of feet up the Monroy would be screaming bloody
murder.
Clearly, you haven't flown with the unit. This statement couldn't be
more wrong. The antenna characteristics are such that traffic being
more than 1500 or 2000 feet different in altitude will not be
annunciated. Altitude has NEVER be a problem for us in actual
operation. Whenever you get a warning for traffic close enough to be
visible, when scanning outside in a sensible range, you'll spot that
traffic, on our experience. Thus, I have looked at the vrx with
interest from a gadget freak standpoint, but I don't think the altitude
sensing would be worth that much money to me. I would, however, love to
see the vr in action.
Old September 18th 03, 02:23 PM
Thomas Borchert
BHelman,
Hmm. Simply doesn't happen with ours. Do you have the feeling that,
apart from the altitude feature, the general detection is more reliable
with the "new-gen" Surecheck unit? IOW, would you think that even
without the altitude indication, the vr would be a better unit than the
Monroy?
Thomas Borchert (EDDH)
Old September 18th 03, 02:36 PM
James M. Knox
(BHelman) wrote in
om:
even some that never existed at all!) would set it off, ...
There is a lot of confusion about the Monroy unit, part of the confusion
frankly sponsored by the Monroy web site and advertising.
What's in it: Not bloody much. Just a simple RF power detector (a
simple receiver with RSSI output). The rest is literally just bells and
whistles - a simple processor to work the lights and voice and make some
fairly clever decisions.
How it works: The data stream itself isn't even available, much less
looked at. The processor just looks at the received power level and
guesses at the range. What it *does do* that is really kind of clever
is look at the LENGTH of the power burst to determine what the
transmission is. Short is a Mode-A/C. Longer is Mode-S. Too short or
too long is noise.
That's it. Nothing else. The "cylinder or protection" that is shown in
advertising is nothing but the limits of the sensitivity of the
receiver, coupled with the simple physics for the radiation pattern of a
monopole antenna. [Which, as you observed, is highly distorted by many
factors.]
Having said all that, I do fly with mine. Yes, some days it is a royal
pain with almost constant false alarms. But where it *is* useful is in
those parts of Texas where you haven't been within 100 nm of another
plane for the last 3 hours. It's real hard to keep as active an outside
scan under those conditions as you think you do. The Monroy is a good
"wake up" backup system.
False alarms: There are many places within short range of my home
airport that will ALWAYS set the Monroy off. Rows of chicken coops seem
to do it. Lots of little microwave telemetry sites on the ground will
do it - the bigger higher power ones don't seem to. Areas of poor radar
coverage will often cause your own transponder to set it off - not sure
why.
And then sometimes it is just a cause best left to Mulder and Scully.
No known cause. [With practice, you *do* seem to get a little better at
noticing certain false alarm "patterns" that help keep you from getting
so concerned about that "traffic" that you just can't see.]
For the money, it is an amusing little device, and just might actually
save someone some day. It is just sad that the FAA has had ADS-B
capability available for almost 20 years and not promoting it any
harder.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old September 18th 03, 02:56 PM
CriticalMass
"Thomas Borchert" wrote in message
operation.
It *has* to be affected by the limits imposed by positioning in the
particular aircraft, internal antenna vs external, etc.
My experience varies with yours. I get alerts often from flight level
traffic I never see, and I get some alerts from same altitude traffic so
late it worries me.
Old September 18th 03, 04:28 PM
Thierry
Marco,
Don't have feedback but i noticed they delayed delivery multiple
times.
A new higher performance system will be available soon at a nearly
same
price of the VRX unit which will display simultaneously 3 threat
aircraft information including the aircraft SQUWAK. This new device
will also integrate an altitude alerter.
Everything is packaged in a small box consuming only 1 watt compared
to 5 watts minimum for the Trafficscope system.
Feel free to contact me should you need more info.
Regards,
Thierry
"Marco Leon" mleon(at)optonline.net wrote in message ...
I cancelled my previous order for their TPAS 100 after I heard the terrible
reviews from the newsgroups and some aviation publications. Through a Google
search I was only able to find one guy's [really short] review which was
positive.
Anyone care to share what they heard or experienced with the TrafficScope?
Marco
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old September 18th 03, 04:46 PM
Thierry
Hello,
A new higher performance unit will be available from end of
October.(R5)
Price will compare to the TrafficScope VRX unit for functionalities
close
to the Ryan 8800 which sells at 6500 USD.
It will display SIMULTANEOUSLY up to 3 threat aircrafts information
including
SQUWAK (not provided by the trafficscope unit), altitude (absolute MSL
or relative to your altitude) and estimated distance.
Horizontal range is programmable up to 10 Nm and vertical up to
Unlimited.
The unit works airborne or on the ground to monitor traffic around.
It's amazing to actually see a commercial jet above and watch its
squawk, altitude and distance displayed on the unit.
Our unit consumes only 1 watt compared to 5 to 12 watts for the other.
We integrated in the same box an altitude alerter to track your cruise
altitude. FREE
To be completely fair you should know that I own the new company who
developped this system.
Those who are interested could contact me at
Regards,
Terry
ProXalert is a trademark.
TrafficScope is a trademark of Surecheck (c)
ps: Have a look at
www.proxalert.com (Prototype site under
construction ...)
Thanks. The consensus is that the Monroy was better than the Surecheck TPAS.
I wouls be curious to see if the Monroy still holds up to the Traffic Scope.
Be sure to post a review if you ever get a chance to fly with the new
SureCheck box.
Marco
Marco,
We have the Monroy ATD200 in our Tobago - works great! However, the new
generation Surecheck units (something vr) look interesting.
Old October 1st 03, 06:19 PM
CriticalMass
"Thierry" wrote in message
om...
same
Intriguing news, but I must be missing something. Why do I care what code
my traffic is squawking? It's never mentioned except on initial contract
with ATC.
Old October 1st 03, 09:41 PM
Thomas Borchert
CriticalMass,
I'm interested in the group's opinion on this. Also, would you care to look
at the display tracking three targets? When three other aircraft are out
there, I'd want to be looking outside for them. Oh wait, my RIO can do the
tracking ;-)
Seriously, though: What do you guys think of these features?
Thomas
Old October 2nd 03, 03:00 PM
Thierry
"CriticalMass" wrote in message ...
om...
same
with ATC.
Hello,
First of all if a traffic is following you, could identify it by its
squawk number. If you don't have the SQ displayed you may think this
is a new traffic crossing your path. If you have it you could also ask
your ATC more info about a specific SQ. This will greatly help the ATC
to answer precisely.
You could also check if it's a VFR or not (1200, etc).
Displaying three threats simultaneoulsy will help you take the proper
flight level in order to avoid them all. ie : One threat "A" 200 ft
below, one 200 ft above "B". To avoid "A" You climb 200 ft and risk a
collision with "B".
Our device also distinghish threats squawking mode A only (no altitude
reported). Check if the other do the same.
Check also our receiver dynamic : 60 db typical compared to 40 db
which allow
us to offer a maximum range of 10 Nm instead of 5 Nm.
This parameter gives you a good indication of the overall quality of
our radar receiver.
Our typical power consumption is 1 watt compared to 5 to 12 watts for
the TS. This is a large difference. Imagine this small box on your
dashboard during a sunny day. Internal temperature will quickly exceed
the functional limit.
This will also impact the reliability of the device. Electronic
devices don't heat.
Last but not least you get an altitude alerter for free + free
lifetime software upgrade thru our web site.
I recommend you double check the exact level of performance of the
competitive device(s). I was reported a number of inaccuracy
concerning their previous generation device.
Finally you get all these functionalities for nearly the same price.
Rgds,
Proxalert
Old October 13th 03, 10:28 AM
BHelman
To be up front I got a trafficscope and have been very pleased with
its performance. But your post made some points I felt I wanted to ask
or address.
"Check also our receiver dynamic : 60 db typical compared to 40 db:
our radar receiver."
Correct me if I am wrong, but doesn't dynamic ability indicate range
of reception, not "quality" of the receiver? example 5NM or 10 NM? I
have been a HAM operator for over 6 years and my experience is that
S/N ratio is an indicator of "quality" not reception dynamics right?
"Our typical power consumption is 1 watt compared to 5 to 12 watts for
the TS."
I run my trafficscope off of the adapter which uses aircraft power, so
why should power consumption be of concern? even 20 watts is minimal
power draw on a 14 volt system. Does your unit have a battery
compartment or do you have to lug around a battery pack (like some
headsets) because frankly battery packs are more clutter.
As far as squawk goes most of the aircraft (I would say 90%) that I
fly around are on 1200 "VFR" so adding this would not be much of an
improvement to advisory conditions.
I saw the website, and it shows an altitude of "65" do you have a way
of showing how that is relative to my altitude? trafficscope gives me
"UP 500 feet" which instantly shows me how far up or below to look, so
by giving their actual altitude, wouldn't that leave the mathematics
up to the pilot to perform?
My last question is what is your company background in producing these
types of devices? Is this the first product they will produce? Has it
been Beta tested?
(Thierry) wrote in message . com...
om...
same
with ATC.
Hello,
collision with "B".
which allow
our radar receiver.
devices don't heat.
Rgds,
Proxalert
SureCheck Micro/VR/VRX Hilton Piloting 0 October 24th 04 03:50 PM
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 12:11 AM
Trafficscope PIREP - long SeeAndAvoid Owning 6 November 24th 03 08:24 PM
Surecheck TrafficScope Pirep? Marco Leon Owning 30 October 21st 03 02:44 PM
Surecheck TrafficScope Pirep? Marco Leon Piloting 20 October 13th 03 03:39 PM
