Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Removing paint from canopy
Old November 9th 03, 05:36 PM
Jason
Default Removing paint from canopy
The Pueblo Weisbrod Aircraft Museum in Pueblo, CO has obtained an
F-104 Starfighter from the US Air Force Academy in Colorado Springs.
The canopy seems to have some sort of paint or coating on the inside
of the canopy. Does anyone know of a way to remove it without damaging
the canopy? Thank you in advance for any help you might be able to
provide.
Jason Unwin
Aerospace Education Officer
(719)948-9219
Old November 10th 03, 11:57 AM
The Raven
"Orval Fairbairn" wrote in message
news
provide.
Jason Unwin
(719)948-9219
DO NOT use paint remover! The TCE in the paint remover will certainly
craze the plastic.
Try a milder sodium hydroxide solution such as that found in some oven
cleaners. Many plastics modellers use oven cleaner aerosols as paint
strippers (acrylics, enamels, and some lacquers) on styrene plastics without
affecting them. If it won't hurt clear styrene it's unlikely to hurt
perspex.
Ezy Off is reputed the best but is stronger than some of the weaker
non-caustic non-fuming varieties The weaker oven cleaners (mostly generics)
shouldn't harm perspex and are a good starting point. Of course, try an
inconspicuos spot first. Odds are the paint won't be anything more than
enamel, otherwise the perspex would already be damaged by lacquers.
Assuming you get the paint off and the perspex is still damaged. A good set
of micro-mesh polishing clothes (which I believe are aimed more at aviation
than scale models) will remove minor scratches etc. If the perspex is
crazed, very little is going to save it, although polishing techniques can
make it presentable.
The Raven
http://www.80scartoons.co.uk/batfinkquote.mp3
** President of the ozemail.* and uunet.* NG's
** since August 15th 2000.
Old November 12th 03, 10:22 PM
Grandpa B.
If the canopy is made of Lexan - and I admit to ignorance here - you can
probably remove the paint with Acetone. I'm rebuilding a '58 Champ, and have
cleaned a bunch of gunk off the windshield so far, with nary a mark on it.
Plexiglas is quickly destroyed by acetone, but not Lexan. Acetone is a very
powerful solvent, and readily eats paints. Powder-coatings, too, I learned.
The hard way, of course!
Jon B.
"Jason" wrote in message
m...
provide.
Jason Unwin
(719)948-9219
Good Paint Remover? Marco Leon Owning 2 June 22nd 04 08:58 PM
Removing paint from windshield tony roberts Owning 9 June 3rd 04 08:53 PM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 04:44 PM
Radar Absorbing Paint robert arndt Military Aviation 2 December 2nd 03 06:09 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 03:51 AM
