Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Ceconite v. Poly Fiber - Is one better than another??
Old March 10th 04, 12:42 PM
DPB
Default Ceconite v. Poly Fiber - Is one better than another??
Hello to the group.
I'm probably going to be acquiring a '46 Champ project in the near future
and I've never done a recover before. I've been reading a little about
Ceconite and Poly Fiber - For you old heads at this - Is one better than
another? Are there plusses & minuses that I should know about before picking
one over the other?
I see from promo stuff that Poly Fiber is supposed to be less weight, which
is important as I want to keep the Champ below the max for the new light
sport aircraft regs.
Any thoughts or comments are greatly appreciated!
Thanks in advance,
Doug B
www.aircrafthomebuilder.com
Old April 30th 04, 05:12 AM
Tom
The fabric is esentially the same polyester on all systems today although
the Polyfiber STC requires "Polyfiber" fabric regardless of the fact it is
not any different than Ceconite.
The choice you need to make is the use of traditional dope, polyfiber's
vinyl system, a combination of PF's vinyl with urethane topcoat or an all
urethane system.
I have just finished covering my Maule with Air-Tech's all urethane system.
You can find them on the web. http://www.airtechcoatings.com/index.html
This system uses "Ceconite" fabric. It is glued on with adhesive that is
the same as PF's basically. Then a urethane two component primer filler is
applied to the fabric. Just a couple coats. After that the urethane high
gloss topcoat. Some people don't like the high gloss on a Champ as the
original dope was not so glossy like a new Mercedes. I found the Air Tech
system easy to use and despite the claims of Polyfiber it is not difficult
to repair. No aluminum coat. The UV protection is built in chemically.
If you want a "traditional" finish the easiest to use is Polyfibers vinyl
system. It gives a similar finish to dope, easy to repair but lacks much
chemical resistance. Easy to spray and not as toxic as Urethane. With
urethane you need a separate air supply and "space suit". No mask will work.
Both Polyfiber and Air-Tech will be lighter in weight than the old systems.
I have found the Air-Tech materials easy to spray with my HVLP unit. Have
heard some comments about the Polyfiber urethane top coats being more
difficult but probably just takes getting used to it.
Just to give equal time Randolph makes systems too.
Regardless of what system you use Polyfiber has the best manual and a good
DVD on covering that can apply to other systems.
Good luck. it will take more effort than you think.
Tom
"DPB" wrote in message
Hello to the group.
picking
one over the other?
which
Thanks in advance,
Doug B
Old May 3rd 04, 01:50 PM
john price
Latest buzz on the grapevine is that Poly Fiber bought out
Randolph, so one might expect to see some changes in the
various STCs on what can be used on what... At least we
can hope...
John Price
CFII/AGI/IGI
http://home.att.net/~jm.price
"Tom" wrote in message
urethane system.
system.
work.
systems.
Tom
Hello to the group.
future
picking
one over the other?
which
Thanks in advance,
Doug B
Old May 6th 04, 04:45 AM
Richard Lamb
can hope...
John Price
CFII/AGI/IGI
Not likely. The chemistry is totally different.
Richard Lamb
Old May 17th 04, 07:29 AM
Roy and Primrose Fox
Is this true and will ceconite continue to be supported?
In Australia the supplier, Avial, have heavily discounted their Randolph
products in order to clear their shelves.
What is happening in the U.S.A.?
Roy Fox
"john price" wrote in message
can hope...
John Price
CFII/AGI/IGI
although
is
all
urethane system.
system.
is
is
Tech
difficult
vinyl
work.
systems.
Have
good
Tom
Hello to the group.
future
than
picking
one over the other?
which
light
Thanks in advance,
Doug B
carbon fiber dutchpilot Home Built 0 June 16th 04 01:20 PM
Ceconite v. Poly Fiber - Is one better than the other?? DPB Home Built 6 March 17th 04 11:25 PM
Carbon fiber vs. antennas Jim Weir Home Built 8 January 2nd 04 02:40 PM
Carbon fiber vs. antennas [email protected] Owning 2 January 2nd 04 02:40 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 05:44 AM
