Have there been any successful tip-jet helicopters?
Old July 24th 03, 05:40 AM
Jeremy Thomson
Default Have there been any successful tip-jet helicopters?
I'm not aware of any tip-jet helicopters that have made it into
production.
Please correct me if I'm wrong.
At first the idea seems a no-brainer, no torque to counter, no
gearbox, should result in a lighter & thus more efficient aircraft.
I suppose the devil is in the details.
Is the problem with tip-jets the rotor hub?
Either you have to pass fuel or hot gas through the rotor hub to the
blades.
I guess sealing a rotating assembly with hot gases flowing through may
be a non-trivial problem?
But that shouldnt be a problem for jets-at-the-tips type designs, fuel
would not be hot enough to damage seals.
Perhaps there is a inherant flaw in the jets-at-the-tips style design?
I've seen videos of the Hughes heavy lift helicopter that directed the
output of a couple of turbojets(/fans ?) through the blades.
I thought that design was successful, it was more a matter of funding
that it wasnt put into production, am I wrong?
Jeremy Thomson
Old July 24th 03, 10:18 PM
Scott Gardner
I can't say it was successful in terms of production, but I did see it fly.
Go to: http://www.intora-firebird.com/main.htm
Scooter
"Jeremy Thomson" wrote in message
m...
production.
blades.
Jeremy Thomson
Old July 25th 03, 04:34 AM
terra
David Lednicer wrote:
The Sud-Ouest SO 1221 Djinn was the only one that was at all succesful.
The US Army evaluated three as the YHO-1.
See: http://www.helis.com/timeline/aerospatiale.php
Did *you* click the link to see the Djinn? With your Netscape 7.02?
Using 7.1, almost every link gets me a popup box telling me I need Netscape 4 or
higher. Duh.
Old July 25th 03, 04:52 AM
terra
Brantly Nuts wrote:
There have been at least 2 tip-jet type helicopters to reach type
certification and production.
Sud Ouest So.1221 Djinn, about 150 produced.
http://avia.russian.ee/vertigo/snias_jinn-r.html
Kolibri H-3, about 10 produced.
http://avia.russian.ee/vertigo/nhi_kolibri-r.html
It says version #1 "was written off through ground resonance". Maybe due to
something like a fuel imbalance through the blades, because 2-blade rotors don't
suffer from ground resonance. Do they?
Old July 25th 03, 12:59 PM
ops
production.
Where does the Hiller YH-32 fit in then?
http://www.museumofflight.org/collec...lay.html?ID=59
http://avia.russian.ee/vertigo/hiller_hoe-1-r.html
rm
Old July 25th 03, 06:59 PM
David Lednicer
I got this when I tried to view it with Netscape 7.02, so I switched and
tried IE 6.0 and it worked.
*White* Helicopters??!!! Stephen Harding Military Aviation 13 March 9th 04 08:03 PM
Taiwan to make parts for new Bell military helicopters Otis Willie Military Aviation 0 February 28th 04 01:12 AM
Sikorsky S-76C helicopters for sale richlady Military Aviation 0 August 21st 03 06:43 AM
FA: The Helicopters Are Coming The Ink Company Aviation Marketplace 0 August 10th 03 06:53 PM
OH-58 for Civilian use pp Rotorcraft 10 July 17th 03 08:53 PM
