Weight and balance..
Old August 15th 03, 02:21 PM
Andrew Crane
"Mike Williams" wrote in message
Could you actually run out of cyclic before running out of fuel and if you
ever got into that situation would a safe or survivable landing be
possible.
e.g running landing or ditching.
Breathe in :-)
The nice thing about the Robinsons is you have the option to raise the
cyclic up to your chin to get the extra stick travel required. Your
limitations with the weight too far forward a
- reduced aft stick movement available
- reduced clearance between tailboom and rotors
- reduced flap/mast clearance
The worst thing is if you're going cross country with lots of people/weight
and full tanks. As you burn the petrol off, you're unaware of the change in
balance because you have a fair amount of forward stick to maintain cruise
speed. It's only when you get to the destination you realise things are
becoming uncomfortable. If weight and balance are going to be an issue,
calculate them with both full and empty fuel before getting airborne,
Regards
Andrew
Inweb Networks. Quality internet and telecoms services
Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk
E1 call share - 65%. 0800, 0845 and 0870 numbers - best rates. Resellers
welcome
Weight and Balance Formula, Can one calculate the envelope Joe Wasik Piloting 12 September 29th 04 09:15 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 02:08 AM
Weight and Balance JP Piloting 2 January 13th 04 11:54 AM
Weight & Balance Question Harry Gordon Piloting 28 December 30th 03 02:51 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 05:08 AM
