Saitek stick/throttle....rudder issue
Old November 16th 03, 05:06 AM
Default Saitek stick/throttle....rudder issue
Hey,
This is a pretty good stick/throttle combination, but it causes a quirky
behavior in that the aircraft rudder becomes very unstable on takeoff roll.
It slips from side to side, making takeoff a real challange. I'm pretty new
with this stick and would appreciate if anyone else having this problem
could give some feedback on it.
Thanks,
Old November 16th 03, 07:57 AM
Dashi
If you are trying to fly a single engine prop, that is the way it should
work. You need to keep a constant left rudder input during take-off and less
of an input in straight and level flight.
I've used the Saitek stick/throttle for a couple of years.
Dashi
"Wayne" wrote in message
Hey,
roll.
new
Thanks,
Old November 16th 03, 04:39 PM
I don't fly prop very often. Usually large commerical jets, (777, 747,
737-800)
So do I keep 'left rudder' on (the rudder toggle button on the underside of
the throttle control)
Thanks.
"Dashi" wrote in message
less
Dashi
Hey,
roll.
new
Thanks,
Old November 16th 03, 11:29 PM
Dashi
737-800)
of
Thanks.
Oops! I mean a right rudder input. The single engine prop aircraft will want
to turn to the left.
Using the rudder control on the Saitek is tedious, I use rudder pedals now.
Dashi
less
Dashi
Hey,
quirky
roll.
pretty
new
problem
Thanks,
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 05:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 11:43 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 10:58 PM
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! Bill Mulcahy General Aviation 3 October 1st 03 06:39 AM
